Old 08-05-2011, 09:09 AM   #1
No power
This morning I woke up and my stove, kitchen lights, and basement lights were not working. (Refrigerator was working). Checked the circuit breakers and they were all on the ON position. Any suggestions on what I can try before calling for help.
jb0416 is offline   Reply With Quote
Old 08-05-2011, 09:18 AM   #2
Electrician
SD515's Avatar
No power
Re-check the breakers. Modern breakers when tripped don’t go to the off position. Sometimes it’s easy to overlook a tripped breaker, as it appears to be on. If it’s tripped, you have to turn it off fully to reset it, then turn it on. If you find a tripped breaker, the next step is to find out why.
Kyle
Old 08-05-2011, 09:18 AM   #3
fabrk8r
fabrk8r's Avatar
No power
Do you have any GFCI receptacles in your kitchen or anywhere else on the circuit serving those areas?
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
The Following User Says Thank You to fabrk8r For This Useful Post:
SD515 (08-05-2011)
Old 08-05-2011, 09:26 AM   #4
Licensed electrician
No power
If the stove is electric, you should call the power company and get them to check the incoming power.
Outdoor Hot Tub / Overhead Power line issue scottwilliamson Electrical 3 02-12-2010 11:37 AM
Devices to save on phantom power fetzer85 Electrical 7 12-04-2009 09:03 PM
Recurring Power Oddities - Regular Schedule DamienChaos Electrical 16 10-21-2009 08:45 PM
Amp meter Results - SE Cable Bad or Power CO jamiedolan Electrical 30 01-23-2009 01:16 AM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
