Old 10-30-2011, 03:01 PM   #1
RR.
No power in 1 room (3 outlets) breaker appears to be fine
I have one room with three outlets in it, none of which are working. I am not entirely sure which breaker controls those outlets but using a multimeter, I verified all breakers are passing electricity through them. The over head light in this room does work, I am not sure if this runs of the same breaker or a different one, also not sure how to test that.
I removed all three outlets from the wall and with the multimeter verified that none of them are getting any juice.
I assume this means that the problem is between the first outlet and the panel, I'm just not certain how to track it down.
RR. is offline   Reply With Quote
Old 10-30-2011, 04:59 PM   #2
Super Moderator
Think like an electrician---Where would you grab the power from for those outlets?
Basement? closet light? switch box? What is the nearest box to that run---?Is there a fourth outlet in the string?
Start by opening up any boxes in the vicinity of the dead string of outlets--
Old 10-30-2011, 05:02 PM   #3
Electrician
Your problem probably is in a working plug or switch, like Mike said start looking at the devices closet to your non working one and start there.
darren is online now   Reply With Quote
Old 10-30-2011, 10:27 PM   #4
Like the others, i agree your issue is at another working receptacle with a broken wire leaving the box. Have also seen many a Homeowner tap from a GFCI incorrectly.
Brick Kicker is offline   Reply With Quote
Old 10-30-2011, 10:45 PM   #5
In which room of the house are these outlets not working?
Was this room added on?
Are there other outlets in this room?
Is there a ceiling light in this room and if so, is it working? Is it a ceiling fan and was that added?
Do you know if there are other rooms on this same circuit? Perhaps there is a label in the breaker panel? If yes, try turning the breaker off, then back on. If that does not work, turn it back off and see what else you lost power to...
Billy_Bob is offline   Reply With Quote
Old 11-01-2011, 07:09 PM   #6
I almost bet its a tripped GFI somewhere in the house.
Have you replaced the receptacles lately or did this power loss just happen all on its own?
longspur is offline   Reply With Quote
Outlets and lighting in new room jgrohol Electrical 9 06-02-2011 10:30 PM
No power to 2 outlets Partsman41953 Electrical 1 02-07-2011 07:52 AM
Loss of power and AFCI tripping Sacslc Electrical 14 11-14-2010 10:12 PM
Loss power To my Outlets. imfocused Electrical 5 07-18-2010 12:19 AM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
