No Neutral Wire... - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Like Tree2Likes
Old 04-16-2009, 09:57 AM   #31
joed's Avatar
Rewards Points: 13,728
Stop using the wires for a clothesline. Put up a proper line if you want to dry your dresses in the basement.
Old 04-16-2009, 05:44 PM   #32
Bigplanz's Avatar
Rewards Points: 996
I am onboard with that one, believe me. Now all I have to do is convince my wife.
Bigplanz is offline   Reply With Quote
Old 04-16-2009, 05:50 PM   #33
Bigplanz's Avatar
Rewards Points: 996
Originally Posted by Speedy Petey View Post
There was never the intent to GFI protect anything but receptacles in unfinished basements.
Here is the exact 2008 NEC text. Not something someone it telling you:
(A) Dwelling Units. All 125-volt, single-phase, 15- and 20-ampere receptacles installed in the locations specified in (1) through (8) shall have ground-fault circuit-interrupter protection for personnel.
(5) Unfinished basements for purposes of this section, unfinished basements are defined as portions or areas of the basement not intended as habitable rooms and limited to storage areas, work areas, and the like
Exception to (5): A receptacle supplying only a permanently installed fire alarm or burglar alarm system shall not be required to have ground-fault circuit-interrupter protection.
For 2008 the exceptions for receptacles that are not readily accessible and for receptacles behind large appliances were removed.
Right you are! I looked into it in more depth this afternoon, and discovered that lighting circuits are not required for GFCI, only circuits with receptacles. Those light fixtures with built in receptacles would, alas, require a GFCI on that circuit. Interestingly, I also discovered that Kentucky has NOT adopted the 2008 NEC, even though it is commonly reported that it has. It seems Kentucky did adopt it, at a administrative level, and that it was then pulled from formal adoption pending 'further study.' The 2005 NEC is still in effect in Kentucky. This link explains it.
http://www.iaei.org/directconnect/states/KY.html
Old 06-22-2017, 07:50 PM   #34
Rewards Points: 2
Re: No neutral wire...
need some answers to a problem
Sparky9845 is offline   Reply With Quote
Old 06-22-2017, 09:43 PM   #35
Licensed electrician
Rewards Points: 1,876
Please start a new thread instead of dredging up zombies.
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
Is using a ground wire as neutral wire safe? Head Fred Electrical 9 12-18-2008 02:37 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 04:58 PM
Sub panel grounding sluggermike Electrical 27 11-11-2007 01:23 AM
