No Neutral Wire... - Electrical - DIY Chatroom Home Improvement Forum
Old 04-13-2009, 07:59 PM   #1
No neutral wire...
I am replacing my existing end-line light switch with Leviton Acenti ACS15 switch. The switchbox has only 3 wires in it: 2 black and ground. But the new switch requires a neutral wire. What are my options?
Thanks.
valerikim is offline   Reply With Quote
Old 04-13-2009, 08:06 PM   #2
Rewards Points: 150
Send a message via AIM to Bocolo
What are the colors on your switch? As far as I know switches do not have a neutral.
Just looked it up they do have a neutral. Sorry.
One Pound of Knowledge Requires Ten Pounds of Common Sense In Order To Be Useful
Bocolo is offline   Reply With Quote
Old 04-13-2009, 08:10 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Some dimmer switches, timers, etc DO require a neutral.
Your ONLY option is to re-wire the switch loop with a "3-wire" cable so you can have a neutral in that box.
You CANNOT run an individual wire, or a neutral from a different circuit.
Old 04-13-2009, 08:17 PM   #4
I don't think I can do it myself. Do you know what would be the approximate price range for this kind of work if I hire an electrician?
Old 04-13-2009, 08:38 PM   #5
Bigplanz's Avatar
Rewards Points: 990
While I don't recommend it, I have seen the ground used to serve as the neutral for a switch like that. Completely non-code compliant, but it 'works.' I have also seen people ground a three prong receptacle through the neutral to get it to pass a plug tester inspection. We started requiring no face plates and 'receptacles must be left out of the box for inspection' after somebody got caught doing that.
Bigplanz is offline   Reply With Quote
Old 04-13-2009, 08:51 PM   #6
No, No, No -- don't even think about using the ground as the neutral...
georgiasparky is offline   Reply With Quote
Old 04-13-2009, 08:57 PM   #7
Don't use the ground as the neutral, please don't mention about it.
Using the ground as the neutral HAS killed people before. Don't do it.
You said two blacks, this is uncommon, unless your house is wired with conduit or some method that allows you to pull individual conductors.
Do you have access from above? Where do these switch wires go?
Can you provide a picture?
rgsgww is offline   Reply With Quote
Old 04-13-2009, 09:23 PM   #8
Bigplanz's Avatar
Rewards Points: 990
I agree completely, and don't recommend it at all. I think it should be mentioned under the 'never do this' category of advice. NEVER use the ground wire for anything other than an Equipment Ground. The service ground (AKA neutral) must be completely separate from the EG.
Old 04-13-2009, 09:34 PM   #9
Then WHY say: "While I don't recommend it, I have seen the ground used to serve as the neutral for a switch like that. Completely non-code compliant, but it 'works.'" ????
NO, it does NOT work. It creates a situation that is potentially VERY dangerous and needs not be mentioned.
Old 04-13-2009, 09:47 PM   #10
Civil Engineer
Rewards Points: 4,790
I ran into a switch like that recently, it was for a dimmable 12 volt halogen system, the switch required a separate neutral. I had to rerun the circuit to provide the neutral, and it of course needed a separate equipment ground.
Old 04-14-2009, 06:00 AM   #11
Bigplanz's Avatar
Rewards Points: 990
Well, point taken. I wasn't very emphatic in my statement, I grant you. Perhaps I'm jaded, as I work in the regulatory field and see people do stuff like this a lot. It would get flagged on a field inspection and the inspector could have the utility company cut your power off until you fixed it, wired it correctly.
We had a case here about 7 years ago where somebody used the ground as the common in a three way switch. It 'worked' in the sense that the switch performed as intended. Unfortunately, there was a short somewhere else (garage door opener) and since the ground had been bypassed/removed, an open short was created that resulted in a fatality.
Old 04-14-2009, 06:04 AM   #12
This was a well documented case that got a lot of media attention. LOTS of finger pointing. The ones ultimately responsible got jail time as well if I remember correctly.
All I remember with any certainty is that a child lost his/her life.
Old 04-14-2009, 07:08 AM   #13
Rewards Points: 348
Could you use another switch? This switch is a non-dimming and there is no timer or sensor so you should be able to find a switch that does not require a neutral unless the led is important enough to warrant pulling a new wire.
RegeSullivan is offline   Reply With Quote
Old 04-14-2009, 07:47 AM   #14
joed's Avatar
Rewards Points: 12,940
If the switch has two black wires on it then you either have conduit and could pull a new neutral or there are white wires in the back of the box that you didn't find.
Old 04-14-2009, 05:36 PM   #15
Probab;ly an open neutral rather than a short.
The real danger here is if you get an open neutral, the current will follow the ground path and energize anything plugged in or gooked up to a ground wire. In the garage door/wet kid case the current likely flowed thru the ground pin on the GDO, thru the metal components, thru the kid and into the wet cement driveway.
Don't use ground for a neutral.
220/221 is offline   Reply With Quote
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
Is using a ground wire as neutral wire safe? Head Fred Electrical 9 12-18-2008 02:37 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 04:58 PM
Sub panel grounding sluggermike Electrical 27 11-11-2007 01:23 AM
