No Neutral - Electrical - DIY Chatroom Home Improvement Forum
Old 10-14-2012, 05:27 PM   #1
No neutral
put up a new chandalier and I have had an electrician in twice there is power to both the switch and the chandalier each one said possibly the bulbs. The last one called back and said it might be the nuetural because I have the same problem in an outlet and a high hat had both replaced and still the same problem at both those locations.
Amecgrace is offline   Reply With Quote
Old 10-14-2012, 07:33 PM   #2
Rewards Points: 13,960
He may mean a bad or loose nutural. It would show a reading if you checked it but would not work under load.
Unused ground lead as neutral? ramatsu Electrical 13 01-10-2012 07:44 PM
Sharing Neutrals on the same phase electro Electrical 30 08-12-2010 02:10 PM
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-22-2010 11:40 PM
question on the "stubbie" bonding links n175h Electrical 12 10-13-2009 04:09 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 04:58 PM
