No More Switch Loops - Does It Apply? - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 09-07-2012, 07:00 PM   #31
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by Speedy Petey View Post
I love Remcons. Only thing is no one around me stocks them. I have to order 'em.
Check these out my friend....
http://ribrelays.com/p765/CLC212D15.htm
The Following User Says Thank You to stickboy1375 For This Useful Post:
Speedy Petey (09-08-2012)
Old 09-07-2012, 09:48 PM   #32
Msradell's Avatar
Rewards Points: 276
I like the fact it has a timer to shut the light off in case the door is left open!
Msradell is offline   Reply With Quote
Old 09-08-2012, 02:11 AM   #33
E2 Electrician
Me too! the doors get left open all the time.
Old 01-25-2013, 07:54 PM   #34
Rewards Points: 506
Old thread revived.
Subsequent to the wise advice in this thread, I purchased a remcon relay for a closet light. That was the easy part. In the pictures are 2 magnet switches I purchased. One advertised as NO, the other as NC. But both switches have the same function, and I call them a NO switch, because the circuit is open when the magnet is AWAY from the switch.
Does anybody have a suggestion where I can buy a magnet switch which has a closed circuit when the magnet is AWAY from the switch, with confidence?
jlmran is offline   Reply With Quote
Old 01-25-2013, 09:04 PM   #35
Electrical Contractor
kbsparky's Avatar
Radio Shack.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
jlmran (01-25-2013)
Old 01-25-2013, 09:21 PM   #36
dmxtothemax's Avatar
Rewards Points: 5,508
Originally Posted by jlmran View Post
Old thread revived.
Attachment 64394
If what you say in the above post is correct,
And you already have a switch with N/O & N/C,
In your case you would use the N/C contacts !
Your switch can be used for either way depending
on which terminals you use on the switch.
dmxtothemax is offline   Reply With Quote
Old 01-25-2013, 09:33 PM   #37
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
Then you obviously got sent one wrong switch.
Yes, Radio Shack may still have alarm contact switches.
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Generator Transfer Switch Trouble wgramer Electrical 23 11-12-2011 07:23 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
