No Kitchen Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 12-25-2010, 10:56 PM   #1
No Kitchen Lights
Hi folks, here i am on Christmas night and I was fiddleing with a light switch to see how a new dimmer for our ballast lights in the kitchen would work. I did not like it and and reinstalled the old switch. Everything fine except that it seemed with the 3 switches we have for the ballast lights some were turning on and others were not. Not like before. I tried switching 2 black wires on the switch and everything seemed ok-- Lights worked, but as I flicked on and off, I heard a pop somewhere-(I thought the switch across from me that also works these lights) and now they dont work. All the other kitchen lights that work on this circuit work fine. What could I have done? Wife will be mad in the morn. Thanks
misslemike is offline   Reply With Quote
Old 12-26-2010, 07:03 AM   #2
Rewards Points: 1,548
Check for a short circuit where two bare wires touched where they should not have, including if it was working when it popped and then stopped working.
Such a short circuit could damage a switch such as the one you thought gave off the pop.
Old 12-26-2010, 07:41 AM   #3
OK, I checked the wires on all 3 switches for these ballast lights. and dont see anything touching for now. Could all 3 switches not be working if one is blown? Thanks again for the reply
Old 12-26-2010, 04:23 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,608
Without knowing how the three switchs are wired,
It is difficult to say for sure.
If they are wired as a 2 way configeration with an intermediate switch,
then things are a lot more complicated then just a simple
switching arrangement.
As you have taken the wires of the old switch,
did you take note of where each wire came from ?
or did you just assume its a simple on / off set up?
Two way switchs are wired different.
So its possible that you have wired it wrong.
Get an electricain to sort it out.
You will have take it on the chin, when the real boss complains,
after all you did stuff it up didnt you!
dmxtothemax is offline   Reply With Quote
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 08:52 AM
kitchen design: should we remove inner wall(s)? ilyaz Kitchen & Bath Remodeling 4 10-26-2010 07:59 AM
Using same tile for bathroom and kitchen too Matchy-Matchy? Jeanene Interior Decorating 10 03-29-2010 12:38 AM
So I'm Thinking about Doing Renovations on My Kitchen Jim.Lee Kitchen & Bath Remodeling 6 03-15-2010 07:53 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
