No Juice Gfi Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 03-23-2010, 10:28 PM   #1
no juice gfi outlet
I wired up my shed,new sub-panel,switch,three outlets,and a outside sensor light.Things went perfect here is my thing,put in gfi breaker to install an exterior outlet.I have juice to the breaker,wires are live small indicator light on outlet lights up but I have no juice in my sockets.WHAT GIVES thanks for your wisdom.
blak21jak is offline   Reply With Quote
Old 03-23-2010, 10:31 PM   #2
Rewards Points: 506
The illuminated small indicator light on your receptacle might mean that the GFCI is tripped. Try resetting the receptacle.
So, if I read your question correctly, you have both a GFCI breaker and GFCI receptacle, on the same circuit?
jlmran is offline   Reply With Quote
The Following User Says Thank You to jlmran For This Useful Post:
blak21jak (03-24-2010)
Old 03-23-2010, 10:51 PM   #3
Rewards Points: 81
It could possibly be a bad gfi receptacle. Also you said you put in a gfi receptacle. How did you wire it? You should have wired it to the line side. Also did you run anything else off of the receptacle? Most likely you are using a leviton and the greenlight means the receptacle has power. Also if you are using a gfi breaker there is no need for a gfi receptacle. That was the whole point of the breaker. But now you need to go to the panel eveytime you want to reset. I would go with a regular break Afci breaker and put in a gfi outlet.
Chevyman30571 is offline   Reply With Quote
The Following User Says Thank You to Chevyman30571 For This Useful Post:
Old 03-23-2010, 11:39 PM   #4
My GFCI outlets light up an amber light when they have tripped and light up nothing when reset.
HooKooDooKu is offline   Reply With Quote
The Following User Says Thank You to HooKooDooKu For This Useful Post:
Old 03-24-2010, 06:19 AM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
Did you wire the breaker correctley?
The neutral from the circuit wires to the breaker, and the white wire on the breaker wires to the neutral bar in the panel.
The Following User Says Thank You to jbfan For This Useful Post:
Old 03-24-2010, 09:12 PM   #6
thanks,I just used a `regular tamper proof outlet with the gfi breaker.Seem the breaker and the gfi outlet was a little to much.
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 02:44 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
