No Ground On Range Hood - Electrical - DIY Chatroom Home Improvement Forum
Old 02-03-2009, 07:42 AM   #1
Rewards Points: 150
no ground on range hood
so i removed my over the rannge hood because i got a new range and i wanted to replace the hood to match. and i realized that there is no ground in the wiring coming to the old hood. The wire coming from the wall has only white and black but no ground. I was thinking about putting a over the range microwave with a fan. my set up would be just to use those wires and mount a receptical so it can just plug right in. but since the microwave has the 3 prong plug and the wires dont have a ground, what would be my steps to achieve some ground
fabian is offline   Reply With Quote
Old 02-03-2009, 07:51 AM   #2
Licensed electrician
Rewards Points: 1,456
Your over-range microhood will require its' own dedicated circuit all the way back to the panel.
Your new circuit will contain a ground.
Old 02-03-2009, 08:10 AM   #3
Those built in micros need their own circuit. Find where this ungrounded line goes and terminate it at its box. Run a new, 20 amp line.
rgsgww is offline   Reply With Quote
Old 02-03-2009, 08:50 AM   #4
Rewards Points: 150
great. thanks guys. will do. i still have left over 12/2 wire from my bathroom project
range hood through the wall - - -stud in the way pacifier1er Building & Construction 30 05-21-2013 09:23 AM
Cabinet Crown Molding and Hood Range? gate1way2 Carpentry 3 10-15-2008 11:13 PM
Same Circuit: Range Hood, DW, and GD? atty_toconnor Electrical 4 04-08-2008 04:43 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
Can I Wire a range hood to an exhisting outlet? skellies Electrical 2 05-09-2006 04:06 PM
