#1 |
No ground in bedroom
I am selling my house and we agreed to fix the outlets in the bedroom that are not grounded. We have since discovered that there is no ground wire anywhere in the bedroom and do to this we will have to run a ground wire through the walls and to the 5 outlets in the bedroom. I have had 2 different electricans tell me it will take up to 2 days and $500 plus to fix this. Both companies were contacted through Angies List.
Do I have any other options? The buyer has already refused me replacing all the outlets with 2 prong outlets. She wants the room grounded. The house is 60 years old in KS. Any thoughts? Thanks!! Kevin |
#2 |
First thought is that there is no need for grounded outlets in the bedroom so you shouldn't have agreed to the change. However, it sounds like you had ungrounded "3 prong" outlets in the bedroom which is wrong so you should have replaced those with the correct "2 prong" outlets prior to selling the house.
Since you have agreed to the deal you have a legally binding contract and really have no choice and need to have it done (the bids seem reasonable). It never pays to agree to something if you don't understand the costs prior to agreeing. |
#3 |
Two prong or put a gfci in. You wont have a "ground" but you can legally install grounded outlets. It is still safe.
#4 |
The buyer will not accept the 2 prong option. They are insisting on grounding the room. We thought it would be an easy fix. The buyer does not understand that the room was never grounded. So, any other options?
#5 |
UAW SKILLED TRADES
There is no way to properly safety ground or ground reference (for pc connection) an outlet if the grounding conductor doesn't exist. As mentioned you can put a gfci receptacle in or gfci breaker assuming that all the receptacles are on the same circuit. If you use a gfci receptacle you will need to determine which one is first in line in order to protect the other ones off the load terminals of the single gfci.
Code also allows you to run a single green insulated ground wire sized for the circuit back to the panel or any accessible point on the grounding electrode conductors...often it is just as easy to rewire with new cable. Gfci will protect you from electrocution but not shock. It doesn't provide a ground though. In otherwords if a fault is occurring you may recieve a shock just before the gfci trips out but in token it will trip out if you plug something into it or any protected outlet that has a ground fault leak protecting you from exposure to that fault. So all in all very good saftey protection. Would cost you about 15 bucks if gfci receptacle is used. and yes anything from the gfci that is protected downstream can be legally a 3 prong outlet even though the ground wire is'nt there. I would discuss this with the buyer as to what her concerns are for wanting grounded outlets. Maybe someone has misinformed her about how serious that is?? Tell her that even her vacuum is only a 2 prong cord. Kitchens need them IMO or anywhere where a known 3 prong cord is going to be used.
" One nice thing about the NEC articles ... you have lots of choices" Stubbie Last edited by Stubbie; 02-11-2009 at 03:47 PM. |
#6 |
There is no ground wire present, so can we fit a gfci outlet with no wire?
#7 |
UAW SKILLED TRADES
Certainly, the gfci doesn't need a ground wire to work properly that's why they allow it....
![]() As far as fit...it might be a little tight due to being a bit bulky but you can get it in that box most likely..... It is a code compliant fix for safety but will not provide the ground wire some equipment will need.
" One nice thing about the NEC articles ... you have lots of choices" Stubbie |
#8 |
UAW SKILLED TRADES
This will help.....
#10 |
Moderator
The question is, will the buyer accept it?
#11 |
I dont think so, she is being very picky and this is causing a huge problem. It is a 60 year old house and I dont know if she gets that. She wants the room grounded so I will have to run a wire through the crawl space and into the back bedroom and then hook it into all 5 outlets. I do not want to spend that amount of money, when in my eyes it is a simple fix. I am offered to replace all outlets to a 2 prong and that fixes the problem. Am I right?
#12 | |
No ground in bedroomQuote:
Gary |
#13 |
You can run a single ground wire as stubbie mentioned, but it would be just as easy (or hard) to run new romex. If you do go the equipment grounding route, it would look better to run actual romex.
The gfci option is the cheapest thing to do. |
#14 |
UAW SKILLED TRADES
I was hoping we made that clear but I think money got in the way of common sense.....
| Display Modes | |
| Bonding Ground in Conduit | jamiedolan | Electrical | 5 | 01-26-2010 11:14 PM |
| To ground or not to ground, that is the question | cartalker | Electrical | 8 | 10-18-2008 11:12 AM |
| Ground question. | mystery guest | Electrical | 5 | 07-24-2008 01:47 PM |
| Older home -- Open Ground issues, please help | Toyz | Electrical | 1 | 06-15-2008 09:41 AM |
| Subpanel feeder questions | Silhanek | Electrical | 4 | 03-22-2007 07:30 PM |
