No Fixture In Dining Room - Electrical - DIY Chatroom Home Improvement Forum
Old 02-27-2012, 08:54 PM   #1
no fixture in dining room
My small house has an addition that I believe was intended as a "sunroom." The roof is flat and, when punching a hole into the drywall ceiling, it's just a small space between celing and roof. There is no wiring in the ceiling. We now use this space as a dining room and currently have a swag lamp over the table, but I'm not particularly fond of the look. Short of tearing down the ceiling, is there any economical way to run wiring to that room? At the very least, I'd like to try to "thread" the pendant swag wiring through the ceiling to the nearest outlet - is this a possibility? I'm very frustrated with this problem.
krismith is offline   Reply With Quote
Old 02-27-2012, 09:10 PM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
You can't run that fixtures wire through the wall and ceiling. You will have to fish the wire through the wall and ceiling and use proper size boxes and wire for what you want to do. You can look on youtube for some video's showing how this is done.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-27-2012, 09:12 PM   #3
Rewards Points: 14,306
Anything can be done if you have enough money.
It may be best to get an electrition to do it because there more likly to have the needed tools to do the job, and know how to safey do it.
Old 02-27-2012, 09:51 PM   #4
Use wiremold. Run it in corners as far as you can. Paint it the same colour as the wall/ceiling.
fdiddy is offline   Reply With Quote
Dining Room receptacle wiring SW315 Electrical 10 02-09-2012 05:28 PM
painting dining and living room with a quite dark olive green paint probation14 Painting 1 03-19-2011 04:37 PM
Painting a dining room table-Please help mbreihan Painting 4 01-05-2010 07:25 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
"pass-through" from kitchen to dining room? scoobz Building & Construction 10 12-25-2007 08:05 AM
