-   -   No current (http://www.diychatroom.com/f18/no-current-147138/)
DCFear 06-15-2012 01:56 PM
No current
In my bathroom I have a ceiling fan that is fan,heater,light. It stopped working the other day. I can not find and power coming or going from the switch? I think I found the feed line but no current. How does on trace a feed line with no current coming from it?
bob22 06-15-2012 02:04 PM
Have you checked the circuit breaker for that line to see if it tripped?
May be fed from an GFCI outlet (wrongly) that has tripped. Try resetting your outlets.
DCFear 06-15-2012 02:45 PM
No Currant
Bob, Thanks for the quick repley. I forgot to mention the big problem is I can't figure out which breaker this line goes to. The person that wired this bathroom never marked anything.
bob22 06-15-2012 03:01 PM
Usually the breaker handle of the one that tripped is off line from the others. Look in your panel to see if one is out of line; it will likely be the one.
DCFear 06-16-2012 09:00 AM
No Currant
Bob, All the breakers are on. When I put a test light on the feed line in the bathroom I get nothing. I have tried all combination on wires?I was wondering if there is a way to see why none of the wires are "Hot"?
gregzoll 06-16-2012 09:02 AM
Can you get to the fan unit from above? Most likely you are dealing with a "Switch leg". Post pictures of the outlet box.
Jim Port 06-16-2012 09:05 AM
By removing the trim the OP should be able to remove the cover to the wiring junction box.
DCFear 06-16-2012 10:03 AM
No Currant
Thanks guys, I have all the switches removed. All the wires are free I have put my tester on all the wires in different combinations. Even tried a black to black and a white to white nothing happening and it is weird it happen all of a sudden everything was working fine. The unit is old and my first though was the switches or the unit itself is bad but not being able to get any electricity to the switch it self has me very confused.
gregzoll 06-16-2012 10:44 AM
Again, we need pictures. And also, I would go down and cycle each breaker, then go from there. Post a picture of both the outlet box that the switches are in, and the junction box that the wires are sticking out of, at the unit.
There can also be a junction point somewhere, that the connection "blew" apart due to overload. Especially if the person that wired it, either did not use wire nuts, by taping, or used the incorrect sized wire nuts.
DCFear 06-18-2012 12:03 PM
No Currant
Thanks to Gregzoll I found the problem with the no currant. No I can't remember how to reinstall the wires to the switch or the fan itself. The unit is at lease 25 years old Air Care Industries AC 2000 . Has a Fan,Heater and Exhaust Fan. The Switch looks like 3 switchs.
gregzoll 06-18-2012 12:19 PM
If you post pictures, we can help.
DCFear 06-18-2012 12:48 PM
took pictures how do I post them on this site?
