Nmwu Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 03-18-2011, 11:24 AM   #1
Nmwu wire
What size of wire should use @ 100 amp
e.watson is offline   Reply With Quote
Old 03-18-2011, 11:27 AM   #2
Rewards Points: 320
What type of wire? Copper/aluminum? What is the distance that you are running it? What is the load?
teamo is offline   Reply With Quote
Old 03-19-2011, 12:30 AM   #3
" Euro " electrician
frenchelectrican's Avatar
The key item is the distance { in feet or Meters } and load it will be on ?
That will make the diffrence there.
Merci.
Marc
Old 03-19-2011, 09:19 AM   #4
joed's Avatar
Rewards Points: 12,924
NMWU is Canadian cable, Wet Underground. Canadian codes are different than NEC.
Fanimation ceiling fan question: no blue wire from ceiling camrn2006 Electrical 8 03-07-2010 12:19 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 09:16 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
