Nmwu - Electrical - DIY Chatroom Home Improvement Forum
Old 09-03-2012, 05:20 PM   #1
Nmwu
Can we use nmwu wire in the US
Mule98 is offline   Reply With Quote
Old 09-03-2012, 05:26 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I have no idea what that is, but all wire has to be a chapter 3 wiring method.
Old 09-03-2012, 05:29 PM   #3
it is sold in canada rated at 300 v wet applications
Old 09-03-2012, 05:29 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,454
Southwire's CU-NMWU cables may be used in underground installations, including direct burial, at conductor temperatures not exceeding 60C. Southwire Type NMWU also may be used for work in both concealed and exposed areas to the weather in dry and wet locations. The minimum recommended installation temperature is minus 40 C for two-conductor cables - sizes AWG 14 through AWG 6 - and minus 25C for all other sizes. For three-conductor cables the minimum recommended installation temperature is minus 10 C. Material should be properly stored above 0C for 24 hours prior to installation. The maximum voltage rating for all intended applications is 300 volts. Consult the Canadian Electrical Code 1 for further information related to applications.
Canadian stuff.....maybe yes....maybe no....depends on your inspector.....No inspector? You can do what you want.....
ddawg16 is online now   Reply With Quote
Old 09-03-2012, 05:30 PM   #5
E2 Electrician
So the answer is no to the OP.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Mule98 (09-03-2012)
Old 09-03-2012, 05:36 PM   #6
Op ??
Old 09-03-2012, 06:12 PM   #7
Rewards Points: 348
Op ??
Original Poster. Also known as TS or Thread Starter.
herdfan is offline   Reply With Quote
Old 09-03-2012, 07:41 PM   #8
Rewards Points: 610
by the way,,now that you are on the subject....what does IMO stand for..just guessing it means In My Opinion?
techpappy is offline   Reply With Quote
Old 09-03-2012, 07:44 PM   #9
E2 Electrician
Yes, or IMHO - In my honest opinion.
Old 09-03-2012, 07:52 PM   #10
Rewards Points: 506
IMHO - in my humble opinion. ???
jlmran is offline   Reply With Quote
Old 09-03-2012, 07:54 PM   #11
E2 Electrician
either or...
Old 09-03-2012, 08:16 PM   #12
kevinp22's Avatar
kevinp22 is offline   Reply With Quote
Nmwu wire e.watson Electrical 3 03-19-2011 09:19 AM
Spa wiring - NMWU or NMD890? KevinB1 Electrical 4 11-19-2010 10:45 AM
Tips on how I can get this electrical job done for a hot tub in backyard. the punisher Electrical 34 08-24-2010 06:08 PM
