-   -   Nmwu (http://www.diychatroom.com/f18/nmwu-155720/)
Mule98 09-03-2012 05:20 PM
Nmwu
Can we use nmwu wire in the US
stickboy1375 09-03-2012 05:26 PM
12 Attachment(s)
I have no idea what that is, but all wire has to be a chapter 3 wiring method.
Mule98 09-03-2012 05:29 PM
it is sold in canada rated at 300 v wet applications
ddawg16 09-03-2012 05:29 PM
Southwire's CU-NMWU cables may be used in underground installations, including direct burial, at conductor temperatures not exceeding 60C. Southwire Type NMWU also may be used for work in both concealed and exposed areas to the weather in dry and wet locations. The minimum recommended installation temperature is minus 40 C for two-conductor cables - sizes AWG 14 through AWG 6 - and minus 25C for all other sizes. For three-conductor cables the minimum recommended installation temperature is minus 10 C. Material should be properly stored above 0C for 24 hours prior to installation. The maximum voltage rating for all intended applications is 300 volts. Consult the Canadian Electrical Code 1 for further information related to applications.
Canadian stuff.....maybe yes....maybe no....depends on your inspector.....No inspector? You can do what you want.....
stickboy1375 09-03-2012 05:30 PM
12 Attachment(s)
So the answer is no to the OP.
Mule98 09-03-2012 05:36 PM
Op ??
herdfan 09-03-2012 06:12 PM
Originally Posted by Mule98 (Post 1002530)
Op ??
Original Poster. Also known as TS or Thread Starter.
techpappy 09-03-2012 07:41 PM
by the way,,now that you are on the subject....what does IMO stand for..just guessing it means In My Opinion?
stickboy1375 09-03-2012 07:44 PM
12 Attachment(s)
Yes, or IMHO - In my honest opinion.
jlmran 09-03-2012 07:52 PM
IMHO - in my humble opinion. ???
stickboy1375 09-03-2012 07:54 PM
12 Attachment(s)
either or...
kevinp22 09-03-2012 08:16 PM
:laughing::laughing::laughing:
