NM Through Conduit Outside? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-07-2010, 07:43 AM   #1
Rewards Points: 640
NM through conduit outside?
It's alright to run NM cable in the ground outside as long as its in a conduit, am I correct?
BlueBSH is offline   Reply With Quote
Old 04-07-2010, 08:19 AM   #2
Master Electrician
Rewards Points: 3,680
It is not. NM is not suitable for wet locations. Underground is a wet location. You could use UF cable.
brric is offline   Reply With Quote
Old 04-07-2010, 08:33 AM   #3
Just call me Andrew
Rewards Points: 1,020
Yes underground in conduit is wet, no romex.
You can direct-bury UF wire or use THWN wires in conduit. If you buy THHN wire in HD/Lowes, it will likely be rated for both THHN and THWN, just read the wire itself.
What's this for? GFCI protected circuit?
Andrew
secutanudu is offline   Reply With Quote
Old 04-07-2010, 10:41 AM   #4
Rewards Points: 640
Yes GFCI protected circuit, its for an outside sump pump... the house has two of them, one is inside in the basmenet floor, the other is outside and they wired it with romex, and the romex has deteriorated very badly and it was time to do it correctly.
Old 04-07-2010, 10:43 AM   #5
Just call me Andrew
Check your locality, but here, a GFCI protected circuit in conduit needs to be buried 12" (non-gfci 18"). I believe UF wire directly buried has to go 18", but not certain on that.
After a tear in the UF wire that lead to my lamppost and having to dig a 40' trench to rewire...I'd never used direct bury UF again, I like individual strands in conduit.
Andrew
Old 04-07-2010, 11:19 AM   #6
Master Electrician
not sure what the code is where you are but if you use pvc then you don't have to go down as deep. Wether you put direct burial cable in it or thwn wires. The pvc is classed as mechanical protection. Also depends on the traffic of the area.
andrew79 is offline   Reply With Quote
Old 04-07-2010, 11:53 AM   #7
If protected by GFCI before it goes underground then 12" depth
Otherwise 18" unless protected by concrete
I have UF wire, but I won't run anything without conduit
Old 04-07-2010, 12:47 PM   #8
Rewards Points: 640
I'm with you on that, I'd rather hit a conduit with a shovel then a UF cable with no protection over it (i guess some people put 2x4's over them?)
Old 04-07-2010, 01:11 PM   #9
2x4's will rot...even PT if buried
I even put the yellow danger tape in.....2 rows actually
One above the conduit 6" I think ?
Then another Caution tape about 3" under ground
Tags
conduit
PVC conduit - custom offset or bending tns1 Electrical 25 08-29-2011 06:56 PM
Water in conduit MYSTERY feign3 Electrical 4 03-14-2010 09:17 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 07:49 PM
Sheathing/siding around conduit destroyer427 Building & Construction 1 10-20-2009 06:25 PM
Sealing conduit coming into house encased with waterline pacamaroman Plumbing 3 06-18-2009 09:48 AM
