NM Ground Wire Loose Underground - Electrical - DIY Chatroom Home Improvement Forum
Old 02-27-2012, 04:20 PM   #1
Rewards Points: 1,062
NM ground wire loose underground
can NM ground wire run loose underground or do I need to get outdoor grade?
Old 02-27-2012, 04:25 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
As long as you have been around this forum and you ask that question??
You need UF cable or THWN in conduit.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
seansy59 (02-27-2012)
Old 02-27-2012, 04:31 PM   #3
I thought so. Just confirming
Old 02-27-2012, 04:37 PM   #4
I thought because it is ground, the rules are more lenient
Old 02-27-2012, 06:08 PM   #5
A "Handy Husband"
rjniles's Avatar
What are you doing? What are you calling NM ground? NM is a cable assembly with 2 or more insulated conductors and bare ground. NM is for indoor dry locations only.
frenchelectrican (02-27-2012)
Old 02-27-2012, 07:52 PM   #6
" Euro " electrician
frenchelectrican's Avatar
If direct burial the NM is not allowed they are not rated for it. The UF cable are rated for it.
Unless you are going in the conduit ( pipe ) then the THHN/THWN induivual conductors will work the best but the UF cable can work but it will be pain in butt to get in the conduit.
Merci,
Marc
Old 02-27-2012, 08:05 PM   #7
Is this to hook up your cable ground to the ground rod?
M Engineer is offline   Reply With Quote
Old 02-27-2012, 08:31 PM   #8
Pretty sure OP is talking about bare ground wire buried in the ground.
@ amakarevic, if that's the case, then yes you can bury it loose underground
hawkeye11 is offline   Reply With Quote
Old 02-27-2012, 09:18 PM   #9
Yes, ground wire for the cable. Now that that is clarified, what is the minimum requirement (e.g. NM loose). And how deep do I have to bury it if it is in or out of conduit?
Old 02-27-2012, 09:32 PM   #10
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
What gauge wire are you planning on using?
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-27-2012, 09:44 PM   #11
14, I guess. It's just gonna ground cable and phone lines
Old 02-27-2012, 10:09 PM   #12
liscenced electrician
Rewards Points: 538
Those aren't dictated by the nec. I see the cable company any phone company hacks using what looks to be about number 10 or 12
jimmy21 is offline   Reply With Quote
Old 02-27-2012, 10:18 PM   #13
I can buy that gauge just as easily
Old 02-28-2012, 05:26 AM   #14
A "Handy Husband"
rjniles's Avatar
Amakarveic,
What confused us earlier was you calling single conductor wire NM. As I stated NM is a cable. For grounding cable and telephone services, I would use bare wire or green insulated THWN. That wire should be a bond to your electrical service ground.
Why can't you connect Ground/Neutral bus bars on a sub secutanudu Electrical 42 11-07-2012 01:33 PM
Light switch - Taping into ground wire ok? SimpleJack Electrical 2 08-15-2011 07:04 AM
Running new(up to code) ground wire & protection. MikeSF Electrical 25 07-04-2010 04:33 PM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 04:02 PM
connecting ground wire to ground screw amakarevic Electrical 10 12-24-2008 04:28 PM
