NM Connectors - Electrical - DIY Chatroom Home Improvement Forum
Old 02-23-2010, 10:04 PM   #1
Rewards Points: 506
NM Connectors
I've seen NM connectors (clamps) installed in main panels two different ways (clamp outside the panel with locknut inside the panel, and vice versa). Are both methods acceptable?
jlmran is offline   Reply With Quote
Old 02-23-2010, 10:22 PM   #2
Registered User
Termite's Avatar
I've always installed them with the jam nut on the inside of the panel and the clamp on the outside, but that's just because it is what I'm used to seeing. I can't honestly say that there's something illegal about doing it the opposite way, but it would raise eyebrows where I'm from. Technically it would depend on the listing of the specific romex connector itself. When in doubt those little plastic NM grommets work great and install easily!
Old 02-24-2010, 08:22 AM   #3
Licensed electrician
Rewards Points: 1,024
I too install the locknut on the inside of the box. If installed the other way a deduction in box fill should be made for the clamp.
Old 02-24-2010, 09:22 AM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 140
If the panel is in use, and cover by sheetrock, I will turn a connector around with the lock nut outside the panel.
Old 02-24-2010, 10:18 AM   #5
The Arlington black buttons can be installed from outside the panel thru a small slot.
Opinions of Ideal push-in wire connectors Bigplanz Electrical 62 07-03-2014 11:29 PM
Push in connectors vs. wire nuts sanny651 Electrical 5 02-17-2010 09:26 PM
4x4" juntion box in 'leaky' location - no cover or romex connectors culturalenigma Electrical 9 07-29-2009 07:43 AM
What do you think of the push in connectors? jamiedolan Electrical 30 11-16-2008 03:13 PM
Twin Impeller Shower Pump Connectors snowman23 Plumbing 1 11-11-2007 05:33 AM
