NM Connector Question - Electrical - DIY Chatroom Home Improvement Forum
Old 10-31-2008, 01:26 PM   #1
Rewards Points: 876
NM connector question
Hi;
I've seen the newer plastic NM cable connectors, but so far have been using the old metal ones with the two screws that you tighten to secure the cable.
I understand why the plastic ones were introduced, but I am very careful about how tight I make the metal ones.
My question is: Are the metal type NM connectors even legal (as in NEC or local code) anymore?
Ultrarunner2017 is offline   Reply With Quote
Old 10-31-2008, 01:31 PM   #2
They are legal and still very much in use.....but not by me.
NM is much more suited to plastic, non conductive boxes.
Putting metal around NM seems like a heating element waiting to happen. That's why I don't like staples.
220/221 is offline   Reply With Quote
Old 10-31-2008, 01:34 PM   #3
Rewards Points: 876
I have been using the plastic NM staples instead of the old metal ones.
I still like metal boxes, but I can see your point. Plastic would be a lot safer if the ground were to become disconnected. Not likely the way I wire them though.
Old 10-31-2008, 01:41 PM   #4
It's much easier to work on energized circuits in plastic boxes without that pesky ground path in the way.
Old 10-31-2008, 01:42 PM   #5
Rewards Points: 83
Heh, just don't bump that pesky bare ground wire.
Bubbagump is offline   Reply With Quote
Old 11-01-2008, 11:42 AM   #6
Electrician
SD515's Avatar
Rewards Points: 504
I hate those pesky goblins that disconnect my grounds when I’m not looking…though it is Halloween time….
Kyle
