Nm Cable Through Cold Air Duct - Electrical - DIY Chatroom Home Improvement Forum
Old 03-01-2010, 05:40 PM   #1
nm cable through cold air duct
so i was wondering how my kitchen was wired and after tracing the wires around i found nm cable running though the duct work...not perpendicular to the joists just straight running through the duct work...i hate it when people half ass ****! 20 amp circuit too!
joseph2293 is offline   Reply With Quote
Old 03-01-2010, 05:58 PM   #2
Electrical Contractor
kbsparky's Avatar
Was this a "duct" that was created by fastening duct boards or metal over existing framing?
It is possible that the HVAC contractor showed up after the electrical rough-in and used that section of framing for his "ducts" without regard to the wiring already installed in there if this is the case.
-KB
Old 03-01-2010, 06:44 PM   #3
yea possibly but it looks like newer nm cable...so its a possibility but none of the cable was stapled along the way...i just pulled it through
Old 03-01-2010, 07:06 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
maybe the guy fished it in after the rock was on and didn't realize it was a duct cavity.
maybe he was an idiot.
could have been either one.
Old 03-01-2010, 07:58 PM   #5
yea either way you just dont want to find nm cable in a cold air duct...let alone a 20a circuit...ouch!
Old 03-01-2010, 08:59 PM   #6
Registered User
Termite's Avatar
The ampacity of the circuit isn't such a concern...Doing that is bad no matter what!
Old 03-02-2010, 10:38 AM   #7
Yea either 15a or 20a doesn't really matter...but it was a solid 15 foot run through the cold air duct...i have a solution and want to run it by you guys to see if its acceptable...it seems it would be but not completely sure...ill post some pics later tonight
Old 03-02-2010, 06:14 PM   #8
so this is what i was talking about...the 12-2 is coming in from the side of the joist goes into the cold air duct and up the wall through a fire barrier partition...so theres maybe 8" of nm cable in the air space within the cold air duct and is not touching any metal part of the duct itself...the reason i had to run it this way is that the receptacle above it is between these joists...i intend to staple later but would an inspector have a problem with this you think?
Old 03-02-2010, 06:34 PM   #9
jbfan's Avatar
Rewards Points: 530
Yea. an inspector will have a problem with romex going into a metal duct.
Old 03-02-2010, 06:41 PM   #10
doesn't code require nm cable to run perpendicular through the joists if it goes through a cold air duct?
Old 03-02-2010, 06:42 PM   #11
jbfan's Avatar
Rewards Points: 530
Is that a metal duct, or a stud bay used as a return?
Old 03-02-2010, 06:45 PM   #12
stud bay used as a return...the wire isn't touching any ducting
Old 03-02-2010, 06:55 PM   #13
jbfan's Avatar
Rewards Points: 530
You are correct, so it seems this is a violation.
Old 03-02-2010, 08:13 PM   #14
man if it is a violation...i dont see any other way of getting wire to this without putting a hole in the wall...
Old 03-02-2010, 08:30 PM   #15
nap
You talking to me?
nap's Avatar
Oh...that's ugly.
what do you mean "fire barrier" in the wall. If that is a duct space, how would it have a fire barrier in it?
and sometimes you just have to make a hole where you didn't want to have to put one. That's the breaks.
Cold air in duct in furnace room? DIYguy2000 HVAC 6 12-23-2009 10:42 AM
Duct work in garage. flashme18 HVAC 1 11-08-2009 06:29 PM
General Question about a duct lda130 HVAC 7 07-31-2009 05:24 AM
Protect Cat6 cable near AC Power Cable? mfleming Electrical 5 10-31-2008 09:04 AM
Adding a vent in cold room... AllGoNoShow HVAC 1 11-21-2006 11:16 AM
