NM Cable, Etc. Temp Rating - Electrical - DIY Chatroom Home Improvement Forum
Old 05-22-2011, 11:07 PM   #1
Rewards Points: 512
NM Cable, etc. Temp Rating
I'm confused about the wire ampacities, and the physical nature they come in. For example, In the ampacity chart I use (http://www.cerrowire.com/default.aspx?id=46), and in the temperature columns, is NM-B available only in the 60C (140F) range? If so, I guess this is the same with UF? IOW: NM-B is NOT rated for 90C (194F)?
Old 05-23-2011, 01:05 AM   #2
Mad Scientist
If I recall correctly, NM-B is actually made with 90C insulation and marked as such, but the NEC requires that it be used at its 60C ampacity. Same with UF.
McSteve is offline   Reply With Quote
The Following User Says Thank You to McSteve For This Useful Post:
sirsparksalot (05-23-2011)
Running cable under/around laminate floor greenjelly Flooring 4 08-06-2010 10:49 AM
Need help sizing Generator cable dgajr Electrical 2 07-20-2010 01:07 AM
Evaluating a kinked cable dave11 Electrical 5 05-09-2010 11:20 AM
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 07:55 AM
DIY phone junction box for cable telephone service eastie Electrical 5 06-17-2009 08:45 AM
