NM Cable Clamp For Non-metallic Box - Electrical - DIY Chatroom Home Improvement Forum
Old 06-10-2013, 10:47 AM   #1
NM cable clamp for non-metallic box
Hello,
I am adding a switch to an indoor appliance that has no built-in on/off switch. This appliance has a dedicated 40A circuit. I would like to use Square D QO200TRNM AC Disconnect Switch:
http://ecatalog.squared.com/fulldeta...mber=QO200TRNM. I choose it because it's easy to use, compare to the pullout disconnect switch. QO200TRNM has a non metallic enclosure that can be use either indoor or outdoor. It has knockouts on side, back, and bottom:
http://download.schneider-electric.c..._Name=3104.pdf
My question is how to tie a 6/2 romex cable to its pvc case? Can I use the NM cable clamp that is normally being used on a metal box?
Thanks in advance for your help.
TheLeaf is offline   Reply With Quote
Old 06-10-2013, 11:05 AM   #2
JW
mm11's Avatar
Rewards Points: 614
Yes, you can use a metal connector with a plastic enclosure.
What's this for- disconnect for EVSE? If so, why not just use the breaker instead?
mm11 is offline   Reply With Quote
The Following User Says Thank You to mm11 For This Useful Post:
TheLeaf (06-10-2013)
Old 06-10-2013, 11:07 AM   #3
jproffer's Avatar
Rewards Points: 710
I'm not as well versed on the NEC as some, but I can't imagine why you couldn't use a metal cable clamp like you said.
Grounding issues wouldn't be a problem since it's an isolated metal part surrounded by non-metallic parts.
jproffer is offline   Reply With Quote
The Following User Says Thank You to jproffer For This Useful Post:
Old 06-10-2013, 02:12 PM   #4
Yes. This is for EVSE. The breaker for this circuit is in main panel, which is located the other side of my house, and it's outdoor. There is no sub-panel in garage. I would like to have a switch indoor closer to the EVSE.
Is it a bad idea to add an extra switch?
Old 06-10-2013, 04:27 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Use a 60 amp non-fused pull-out disconnect: $6 or so.
http://www.homedepot.com/p/Eaton-Cut...8#.UbZEqtj9VJs
Coastal South Carolina
Old 06-10-2013, 09:24 PM   #6
That's what I planned to buy initially. But if I do that, I will be the only person in my family that can operate the disconnect
Old 06-10-2013, 10:58 PM   #7
jproffer's Avatar
Rewards Points: 710
Why is that? Don't think they're THAT hard to operate. I only browsed over the description, maybe I missed something...??
Old 06-10-2013, 11:52 PM   #8
I agree with you it's not that hard. But for some, a switch must look like a switch.
Old 06-11-2013, 12:16 AM   #9
jproffer's Avatar
Rewards Points: 710
LOL...got it. I was just givin ya a hard time.
Old 06-11-2013, 05:12 AM   #10
A "Handy Husband"
rjniles's Avatar
Get the Square D version, it actually has a switch; $17
http://www.homedepot.com/p/Square-D-...4#.Ubb3g9j9VJs
The Following User Says Thank You to rjniles For This Useful Post:
TheLeaf (06-11-2013)
Old 06-11-2013, 05:28 AM   #11
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You would need a bonding bushing in order to use a metal clamp on a plastic box.
The Following User Says Thank You to k_buz For This Useful Post:
Old 06-11-2013, 07:57 AM   #12
jproffer's Avatar
Rewards Points: 710
Thanks for that. Rather than buy 2 parts I'll probably just quit using metal on plastic lol....but still good to know.
Bringing Wires into the Side of a Panel and Number of Wires in a NM Cable Clamp? Ocelaris Electrical 10 03-05-2013 07:44 PM
Is Tray Cable acceptable for Residential use? MisterSteve Electrical 43 02-21-2012 12:35 AM
Aerial Cable to Garage & Adding Sub Panel CDW59 Electrical 5 12-09-2011 06:43 AM
added circuit to panel, now how to remove the old cable clamp??????! Allthunbs Electrical 7 12-05-2011 05:47 AM
Evaluating a kinked cable dave11 Electrical 5 05-09-2010 10:20 AM
