NM Cable Bend Radius - Electrical - DIY Chatroom Home Improvement Forum
Old 01-23-2013, 12:53 AM   #1
Send a message via AIM to Rich Send a message via Yahoo to Rich
Upgrading/replacing wire throughout a 160+ year old home. We opened the pine plank flooring where the original electrical was added between 50-100 years ago (combination of K&T and old cloth covered 2 wire cable). Pulling the new NM/Romex cable through existing and new holes in the floor joists. When transitioning from going through the joist to run parallel to the joist do I need to leave some kind of slack for bend radius concerns or do I just staple it a few inches from the hole. We're following 2009 IRC here in WV.
Rich is offline   Reply With Quote
Old 01-23-2013, 07:47 AM   #2
Rewards Points: 31
Id leave a little slack, maybe 6 inches then fold it over and staple it...better to be on the safe side...to answer the question, no there is no bend radius
Olsy is offline   Reply With Quote
Old 01-23-2013, 08:09 AM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
334.24 Bending Radius. Bends in Types NM, NMC, and NMS cable shall be so made that the cable will not be damaged. The radius of the curve of the inner edge of any bend during or after installation shall not be less than five times the diameter of the cable.
Old 01-23-2013, 08:09 AM   #4
E2 Electrician
Of course there is... see my above post.
Old 01-23-2013, 08:48 AM   #5
Rewards Points: 31
What i meant was its not a huge amount...so your right
Old 01-23-2013, 08:57 AM   #6
Rewards Points: 6,652
No you do not need to staple. Because it is a retrofit rewire. Now if you were gutting the walls, yes you would have to staple, but not in your case.
Old 01-23-2013, 09:40 AM   #7
How do you figure the diameter of the flat NM cable? Do I need to bring it across the bay to make sure there is enough or can I just leave a small slack bend before I staple it on the same joist that it comes through?
Old 01-23-2013, 05:37 PM   #8
"So I Re-Wired It"
MisterZ's Avatar
i like to picture the size of a baseball. for 12/2 or 14/2 wire this shape would leave plenty of slack.
secure the wire after the bend
Knowledge is Power, but 240v can Keel You!!
MisterZ is offline   Reply With Quote
Old 01-23-2013, 05:44 PM   #9
Master Electrician
Rewards Points: 3,750
You use the largest dimension of the cross section. If it's 5/8" wide that is the number to use as a radius.
brric is offline   Reply With Quote
Old 01-23-2013, 11:14 PM   #10
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
This would be a good example ...
The Following User Says Thank You to Stubbie For This Useful Post:
Hardway (01-23-2013)
Old 01-24-2013, 08:59 AM   #11
I can't find any pictures of anyone doing it like you describe. The pictures that I can find on the web of a penetration of a joist or stud then change of direction with a staple they seem to have done it tight. See link below.
http://www.flickr.com/photos/25155538@N02/2516125035
Old 01-24-2013, 11:19 AM   #12
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Also, holes through framing members are considered secured and supported of the cable.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
Rich (01-25-2013)
Old 01-24-2013, 10:52 PM   #13
MCB
sparky
a bend radius is designed to give you the MAX amount you can bend it if you HAVE to. just make sure the wires are in a gentle curve, you are good to go. Never a flat 90 degree bend, that's all. Don't staple near holes, not necessary.
MCB is offline   Reply With Quote
The Following User Says Thank You to MCB For This Useful Post:
Rich (01-25-2013)
Old 01-25-2013, 09:14 AM   #14
Thanks for the input everyone. Based on the comments I'll make sure I don't pull the wires tight so that if during rough-in the inspector wants me to staple with the slack/bend radius, I can add them in. Seems to be consensus that I should not need them right at the hole though and that's really the only reachable place in the retrofit.
Is Tray Cable acceptable for Residential use? MisterSteve Electrical 43 02-21-2012 01:35 AM
Need help sizing Generator cable dgajr Electrical 2 07-20-2010 01:07 AM
Evaluating a kinked cable dave11 Electrical 5 05-09-2010 11:20 AM
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 07:55 AM
Running Sky+ cable bookersbeauty Electrical 1 04-09-2009 08:12 PM
