-   -   NM cable in accessible attic - perpendicular to rafters? (http://www.diychatroom.com/f18/nm-cable-accessible-attic-perpendicular-rafters-146447/)
keodark 06-08-2012 06:55 PM
Hi all,
I've spent several hours today reading about the NEC code regarding running NM cable in an accessible attic. I apologize if I missed the answer to this, and I know similar questions are asked continually. Because I'm going to build up the joists and blow in an extra 6" of insulation, I don't want to run NM cable through or across the floor joists. I also don't want to drill holes in the rafters to thread the cables through.
This is an accessible attic (permanent pull-down stairs) with very little headroom (around 5' in the center).
My question: Is it permissible by the NEC code to screw a 1x6 or 1x10 as a running board, perpendicular to the *rafters* (high enough to clear the blown-in insulation and be accessible, but not so high as to hit my head on the board), and staple the NM cables (there may be several) to the board at least every 4.5 inches?
Will this be adequate protection, or will I also have to screw 2x4s on edge to provide a guard "at least as high as the cable"?
Thanks!
stickboy1375 06-08-2012 07:02 PM
12 Attachment(s)
Originally Posted by keodark (Post 939355)
Hi all,
Thanks!
Yes, this is fine, if you ran the cables across the top the of the floor joist, you would then need a guard strip as high as the cable, but what you are doing is perfect. You may want to try stack-its on your running board...
http://images.orgill.com/200x200/6797674.jpg
keodark 06-08-2012 07:23 PM
Thanks, Stickboy. I didn't even know those existed! I'll try em out.
stickboy1375 06-08-2012 07:24 PM
12 Attachment(s)
3M makes them, it will save you some time....
Jim Port 06-08-2012 07:39 PM
The cables only need to be secured at no more than 4.5 feet, not inches.
