NM-B Jacket Damage In Drop Ceiling - Electrical - DIY Chatroom Home Improvement Forum
Old 10-18-2012, 09:33 PM   #1
NM-B Jacket Damage in Drop Ceiling
I just happened to be looking inside my drop ceiling in my finished basement and noticed that the jacket on a 14-2 (w/ground) NM-B wire had "split" open in several spots between two recessed cans and the paper wrapper was visible. I shut off the circuit breaker (15amp) and took out the one 6ft run to inspect it closer. I didn't see anything obvious outside of the damage to the jacket. The push-in connectors used in both cans all seemed good. I checked the rest of the basement and all the wire I can visually inspect seems to be in great shape. The cable is dated 9/12/04 and was installed in mid-2005. I do have forced hot air heating and the wire in question was split directly under the joist bay where it ran perpendicular to the duct. I have attached two photos of the wire in question. My big concern is that there was a short somewhere that heated the jacket and caused the damage.
Replacing the wire that is damaged is the obvious first step but should I be looking at replacing the two cans between the wires as well?
NM-B Jacket Damage in Drop Ceiling-photo2.jpg   NM-B Jacket Damage in Drop Ceiling-photo.jpg
clydesdale is offline   Reply With Quote
Old 10-18-2012, 09:38 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,860
That's not melted. It looks like mechanical damage, like it was pulled over a very sharp edge. It also could be a manufacturing defect. I really wouldn't worry about it. If the insulation on the conductors inside isn't damaged, just wrap it with electrical tape and leave it alone.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is online now   Reply With Quote
Old 10-19-2012, 06:18 AM   #3
Electrical Contractor
kbsparky's Avatar
Damage from poor installation technique. Wrap it with some good electrical tape and call it a day.
-KB
Old 10-19-2012, 08:59 AM   #4
Licensed Pro
I've seem Romex like that right off of the coil... a manufacturing defect. As long as everything inside is intact, not a problem.
Drop Ceiling Idea buildit45 Building & Construction 11 12-06-2012 02:09 PM
Drop Electrical box for Ceiling Fan into Boxed in Beam incufilter Electrical 6 07-01-2012 11:45 AM
Cans in a drop ceiling with 4" clearence RegeSullivan Electrical 3 04-27-2009 11:55 AM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 09:27 AM
