-   -   NM to Armored Cable Transition? (http://www.diychatroom.com/f18/nm-armored-cable-transition-30982/)
toddmanqa 10-31-2008 02:40 PM
I am in the process of renovating a room in Albany, NY, and have exposed the studs in order to add insulation and re-do the old wiring.
I plan on using NM (Romex) wire, and plan on running the NM down a plumbing chase to the basement, and then run to the electrical panel.
Does the NM have to be in armored cable or conduit in the basement/plumbing chase, or can I staple it to the bottom of the joists in the basement? (I'll be fireblocking the chase as soon as I'm done.)
If I do use Armored Cable or conduit in the basement, what is the correct way to transition from NM?
Note: I didn't want to use armored cable for the room wiring because I wanted to use plastic receptacle boxes.
Thanks for any advice!
amakarevic 10-31-2008 02:43 PM
not to different except that armored cable requires special clamp connectors going into a receptacle. you may find out that your legacy armored cable does not have a ground wire, in that case you most likely want to piggytail your incoming NM ground around a brace on the receptacle or something like that - i am not sure but would be curious to confirm from a more credible source.
Bubbagump 10-31-2008 02:46 PM
Generally you are required to staple wiring to the SIDE of joists. (at least around here you do.)
As for a hand off between NM and BX (assuming you really meanAC), a metal junction box with BX in one side and NM out the other will work fine. be sure to ground the NM to the box.
rgsgww 10-31-2008 02:57 PM
I already helped someone with the same thing, I already have a post on this with pictures check it out
http://www.diychatroom.com/f18/armored-cable-30648/#15
Remember you NEED bushings, and the armored cable NEEDS to have a bonding strip in it!
amakarevic 10-31-2008 03:10 PM
do they have special receptacle boxes with little hooks inside them to piggytail the NM ground to instead of piggytailing it to a receptacle brace, which interferes with screwing the cover on ?
Bubbagump 10-31-2008 03:12 PM
Grounding clips, yo. Or there are threaded 10-32 holes in the back of the box to ground to.
amakarevic 10-31-2008 03:18 PM
is this something than needs to be purchased separate from a receptacle and inserted into a hole you are talking about ?
Bubbagump 10-31-2008 03:20 PM
You are rewiring a building? Eeesh... Really, get your work checked out.
That said... many boxes come with a screw already in the back of the box to connect the ground to. If there is no hole, then a grounding clip must be used. This is a green clip that connects a ground wire to the box. They are like 15 cents each.
See here:
http://www.itw-fastex.com/catalog/in...ce296908e9109e
amakarevic 10-31-2008 03:29 PM
exactly what i thought. thanks.
