NJ (NEC 2008) Adding Ground To BX Cabling - Electrical - DIY Chatroom Home Improvement Forum
Old 08-31-2010, 02:49 PM   #1
NJ (NEC 2008) Adding ground to BX cabling
Immediate apologies if this has been asked and answered, and immediate thanks for links to any answers from this site or otherwise.
I've gone through the forums and have read quite a bit, and even have gone through the NEC 2008 for some of the definitions. I do have some follow up questions, particularly surrounding this thread here on the forums.
Is it safe and compliant to run a grounding conductor down to the circuit breaker panel where the main ground is? It seems like in lieu of running new Romex (trying not to tear out walls), or setting up GFCIs (want to use computer equipment in the rooms) running a dedicated conductor line might be the easiest way to go.
Thanks again.
skormos is offline   Reply With Quote
Old 08-31-2010, 03:20 PM   #2
Hrm... doing more research it seems like I may have found the answer in this post and in this one here.
Tags
ground , nec2008
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 05:02 PM
conduit coming out of the ground, or exiting building near the ground wmldwilly Electrical 10 05-24-2009 05:44 AM
adding a ground to an ungrounded recepticle SS396 Electrical 41 09-16-2007 05:56 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 03:59 AM
Adding a ground bar Chemgeek Electrical 1 02-18-2007 01:28 AM
