Nicks On Electrical Wiring - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 09-02-2008, 02:23 PM   #31
Licensed Pro
I don't know how you came to the conclusion that I said that #14 is rated for 20 amps. The insulation has to be designed to be capable of withstanding the heat generated when the conductor is over loaded 100%. For #14 wire, this would be 30 amps.
#14 THHN has an ampacity of 25A, so if it can withstand an overload of 100% of its rating, then it would be 50A, not 30. At least get your figures right.
Old 09-02-2008, 03:31 PM   #32
This jousting serves no purpose!
Lets stick to the original post about wire nicks.
We are all aware of the the various insulation qualities, so lets get back to the original post.
As TW is the basic insulation level for NM cable for residential wiring, it is assumed that we are discussing this! For any other application, it should be stated what this is.
You have demonstrated your command of the NEC, which is commendable.
As your intent seems to be to dominate, rather than educate, I cannot see the value of furthering this discussion.
I wish you well, and good-bye!
Old 09-02-2008, 04:15 PM   #33
Licensed Pro
NM-B cable uses THHN wire. If you are going to give out information, please make sure you are giving out the correct information.
Old 09-03-2008, 10:58 AM   #34
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
The advice and statements I see on this forum are getting worse and worse. And in this case, very dangerous. Some DIY guy is going to read your posts and think he can safely wire up his dryer or range with #14 NM if he just considers the "safety factor."
I'm out of here.
John
jrclen is offline   Reply With Quote
Old 09-03-2008, 03:36 PM   #35
Power Gen/RS Engineer
Rewards Points: 566
Amen. Something that you'd expect to find on Yahoo answers, huh John?!
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 09-03-2008, 08:48 PM   #36
jrclen's Avatar
Rewards Points: 514
Oh Jeesh, I did tell the people over there that they could get better answers over here.
John
Help with electrical timer wiring Jack417 Electrical 2 07-05-2007 03:26 PM
Electrical wiring running parellel and through ductwork? Beren HVAC 4 06-02-2007 01:32 AM
Electrical wiring running parellel and through ductwork? Beren Electrical 1 06-01-2007 05:08 PM
electrical wiring in bath. pinman52 Electrical 4 05-04-2006 07:01 AM
Electrical wiring jonathanm1978 Electrical 1 02-03-2006 12:57 PM
