Nicked Romex In Demo... Splice Or Re-run? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-10-2009, 12:52 PM   #1
LeviDIY's Avatar
Rewards Points: 252
Question
Nicked Romex in demo... splice or re-run?
Hey all... was ripping out drywall in the kitchen... slow going... brought out the reciprocal saw to speed things up... thought I mapped out all the lines in the wall...
... and of course, nicked the supply line feeding the outlet the saw was plugged into (how I knew, of course) and its out .
On closer inspection, the nick is real slight, looks like it severed just a tad in the line, but obviously enought.
Can I "splice" romex, and electrical tape it up or just run from the previous box a new line?
Both easy tasks, as the walls are open, just wondering... also save a trip to the store
LeviDIY is offline   Reply With Quote
Old 08-10-2009, 01:20 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Re-run the wire.
wirenut1110 is offline   Reply With Quote
Old 08-10-2009, 02:03 PM   #3
Registered User
Termite's Avatar
If the jacket of the romex is the only thing that got nicked you're fine doing a good tape job on it with good quality electrical tape. If the conductors' insulators were nicked you have no choice but to re-run the wire.
Old 08-10-2009, 02:18 PM   #4
300zx's Avatar
Post
Or add a j-box if wires will reach.
300zx is offline   Reply With Quote
Old 08-10-2009, 08:59 PM   #5
Rewards Points: 1,016
To avoid this from happening, I break off a sawz-all blade so it's only about 1/2 long at the longest of it's stroke. You can saw right over studs, not catch wiring, etc. Works great.
Old 08-11-2009, 01:05 PM   #6
Rewards Points: 204
If it's that minor he needs no tape either.
Old 08-21-2009, 11:32 AM   #7
LeviDIY's Avatar
Rewards Points: 252
Update for ya'll: just removed the romex, ran a new line... I inspected the wire once removed... cut through the outer insulation AND the black/hot wire... now the saw was plugged into the outlet who's connection was severed at the time, so not sure HOW I didn't get zapped pretty bad, but I didn't. Did the saw just conduct/ground itself? Or was it just so fast that I was really really lucky?
Old 08-21-2009, 08:47 PM   #8
If the saw has a 3 prong plug, it should have blown the breaker to protect you!
If it has a 2 prong plug, it will have a double insulated case to protect you!
Old 08-22-2009, 11:06 AM   #9
If the line were not possible to re-run, TYCO makes a Romex Splice Kit (CPGI) that is NEC Compliant-(Article 334-40b, 2005 NEC that allows 12 or 14 AWG to be spliced in walls without a junction box.
RetiredKeith is offline   Reply With Quote
Old 08-22-2009, 12:26 PM   #10
" Euro " electrician
frenchelectrican's Avatar
That kind of item you are describing here that is common to find in mobile homes effer them more than half useally pretty much done damaged from overload or bad connections one of the two.
But for standard buildings for remodeling it kinda hard to get the inspector to pass it most will say remove it and use standard junction box and be done with it.
Merci,Marc
Tags
romex , splice
Extra wire to do pigtails for outlet...splice romex? RyanD Electrical 3 05-12-2009 11:05 AM
Connecting Romex at Panel Bocolo Electrical 14 02-21-2009 05:55 AM
Romex Splice Kit hogger9 Electrical 9 10-09-2008 07:32 AM
Cost Difference Between Conduit & Romex Shawns4 Electrical 39 08-25-2008 05:01 PM
Splice box/s between subpanel and main panel? SeanR Electrical 5 05-06-2007 02:21 PM
