Nicked romex cable behind drywall
As long as the copper wasn't damaged, electrical tape will be fine. The tape should have a 600v rating matching the insulation rating of the conductors. The outer jacket is not insulation so taping the is no problem either. If the copper conductor was compromised in anyway it will have to be spliced using an approved means and be accessible.
All responses based on the 2011 NEC.
If you live in New Jersey click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . All other states click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. .
Please check with local, county and state officials as laws may vary.
Sizing motors To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online motor calculator To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online calculators To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. .
