Nichrome Heater - Electrical - DIY Chatroom Home Improvement Forum
Old 03-26-2011, 01:38 PM   #1
nichrome heater
Hello,
I have an electric fireplace with. Heater that uses an element with nichrome wire wrapped around 2 insulator plates it has 2 windings. One for low and 1 for high. When both windings have electricity that is HI. If only one is on then it is on low. There is a fan to blow the hot air out. This is basically a hair dryer.
Each element ( wire ) is 466 watts @ 110 volts. With both on it uses about 10 amps and gives off just under 1000 watts. I would like to get it ( nichrome element) rewound to use 220 volt. There buy saving cost as it will only use about 5 amps assumming it is still for 1000 watts.
Can someone provide info on nichrome wire and how to rewire this? I can not find any help.
I can send picture.
Sandro
sandro is offline   Reply With Quote
Old 03-26-2011, 01:58 PM   #2
Electrician
Warhawk's Avatar
nichrome heater
There is no savings by doubling the voltage. Watts are watts. 10 amps at 120v is 1200 watts. 5 amps at 240 volts is 1200 watts. You pay for your power by wattage use, not amperage use.
Warhawk is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 04:29 PM
Would like to use Nichrome wire to make a small heater GerGa Electrical 35 10-14-2009 04:40 PM
Trying to create a nichrome coil heater that runs off cr123 batts freddo Electrical 10 04-12-2009 01:21 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
