That Nice Tight Twist - Electrical - DIY Chatroom Home Improvement Forum
Old 11-05-2011, 07:38 PM   #1
Rewards Points: 348
That nice tight twist
OK electricians! Tme to give up one of your secrets!!
I have 3 twelve gauge wires in a junction box and will wire nut them (basically a ground coming off a receptacle and going to another receptacle). When I look at another one that an electrician did, he somehow wraps those three wires nice and tight around each other and then wire nuts them...how the heck do you do that wrap? I've tried pliers to no avail! Certainy trying to twist them by hand doesn't get me very far.
dougp23 is offline   Reply With Quote
Old 11-05-2011, 07:41 PM   #2
Electrical Contractor
kbsparky's Avatar
This is what separates the pros from the rest!~
You need a bigger pair of pliers (we use "linesmans" pliers for such tasks)
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
gregzoll (11-06-2011)
Old 11-05-2011, 07:44 PM   #3
That's just my opinion. But it's free, so take it for what it's worth to you.
1910NE is offline   Reply With Quote
Old 11-05-2011, 07:48 PM   #4
Rewards Points: 348
Ah yes, we used to call these our "Kleins" - even though all our tools were Kleins, for some reason these pliers were "your Kleins" - as in "I didn't bring my hammer, hand me your Kleins". We used to beat those poor things, but they never quit.
I was trying with the needle-nose. Close but no cigar.
Old 11-05-2011, 08:01 PM   #5
Electrician
Rewards Points: 794
Plus the 1000's of joints electricians have practiced on.
No real secret, line up the ends of wire and twist slowly, its not a race take your time. Then do 1000's of joints and you will have joints that look like a pros.
darren is offline   Reply With Quote
Old 11-05-2011, 08:47 PM   #6
Rewards Points: 1,192
Strip the wire long and you'll have more to work with.
bobelectric is offline   Reply With Quote
Old 11-06-2011, 10:01 AM   #7
Rewards Points: 160
Some electricians don't pre-twist the wires at all. It is not a requirement to twist the wires before installing the wire nut. Why do you think someone invented the wire nut? To eliminate twisting and soldering.
Old 11-06-2011, 10:03 AM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
Exactly....that nice twist your seeing is what happens when you twist the wirenut enough. Hold the wires about 2" from the nut and twist with the tool.
ddawg16 is online now   Reply With Quote
Old 11-06-2011, 12:00 PM   #9
kbsparky's Avatar
Originally Posted by dougp23 View Post
....I was trying with the needle-nose. Close but no cigar.
I can do it with needle-nose. But then again, I do this sort of thing all day, most every day ...
-KB
Old 11-06-2011, 12:07 PM   #10
Code05's Avatar
Rewards Points: 1,104
Nah, I am a pretwister. Too old to change.
Code05 is offline   Reply With Quote
Old 11-06-2011, 12:29 PM   #11
Electrician
SD515's Avatar
Rewards Points: 504
Me too...except I don't use pliers...just my hands.
Kyle
Old 11-06-2011, 01:53 PM   #12
Electrician
Rewards Points: 794
You have to see me twist #10 solid together with my hands.
Old 11-06-2011, 02:51 PM   #13
JOATMON
ddawg16's Avatar
Oh yea? You should see me twist 00 with my bare hands........
Old 11-06-2011, 03:01 PM   #14
Electrician
Rewards Points: 794
What size marrette do you put on there when your done??????
Old 11-06-2011, 05:11 PM   #15
Licensed electrician
Rewards Points: 1,630
Big ones.
Best way to get off a tight bolt in cramped workspace, under car amodoko Automotive Repairs 15 09-03-2011 12:41 AM
is there a trick to twist fitting type B vents amakarevic HVAC 4 07-14-2011 10:08 PM
How tight is too tight for a new basement wall? vseven Building & Construction 16 01-07-2010 08:50 PM
Making nice tight bends in 1-1/8" Suction Line hennyh HVAC 8 10-28-2009 10:13 AM
insulating tight spots rtoni Building & Construction 7 12-10-2008 09:33 AM
