Newbie's First Question, Pinched Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 12-30-2008, 10:29 AM   #1
Newbie Bill
Rewards Points: 520
Newbie's first question, pinched wire
Hello everyone,
Thanks to all the experts here for giving me a newfound respect for the multitude of electrical issues. It is more than just running wire.
I have an undeveloped basement and have those pull chain lights and the strings constantly slide off the chain.
I had to loosen the fixture to shake the chain out and as I was tightening the fixture, I pinched the black wire up against the metal box and the fixture and had a bit of a spark show. So I turned the power off, went back in and noticed a nick in the sheathing of the black wire, I taped it up with electricians tape and put it back together.
After reading the multitude of posts here I thought I better ask if this fix is sufficient or should I go back in there and cut the wire back to the nick?
Oh yeah, my next task is to hook up a switch to those lights. I'll deal with that in another post.
Sincerely,
Newbie Bill
drtbk4ever is offline   Reply With Quote
Old 12-30-2008, 10:40 AM   #2
Res Ipsa Loquitur
If you have sufficient extra wire after cutting to the nick, I would do that to clean it up. If you have the room you could also extend it (with wirenut) using a piece of the same gauge & color wire if necessary. Nicking the wire essentially makes it a smaller conductor and adds a weak spot for future breakage.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 12-30-2008, 10:47 AM   #3
Registered User
Termite's Avatar
A tape repair isn't good enough for repairing the insulation of the conductor. As handyman said, if you have sufficient length it would be wise to cut back to the damage and re-wire.
Old 12-30-2008, 11:20 AM   #4
Newbie Bill
Rewards Points: 520
OK, I will do that guys, thanks.
3 wire to 4 wire question macmouse Electrical 24 05-01-2008 05:34 AM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
Does a 6 x 12ga wire nut exist? peeks Electrical 1 10-02-2005 09:58 AM
Electrical receptacle replacement question sherlock Electrical 7 05-20-2005 03:33 PM
New fixture wiring question Unregistered Electrical 1 02-22-2004 07:34 PM
