Newbie Questions, Subpanels - Electrical - DIY Chatroom Home Improvement Forum
Old 10-28-2010, 10:13 PM   #1
Arrow
Newbie questions, subpanels
Hello,
I am extremely new to anytype of sophisticated electrical worrying soo an explanation in very simple terms would be very nice and hickey appreciated
My question
I wish to illumiate my side yard tennis court. From my limited knowledge, I believe I must install a subpanel? Am I right or wrong?
Davester is offline   Reply With Quote
Old 10-28-2010, 10:19 PM   #2
The answer to your question requires some other information but here's my thoughts on it and I'm sure that I will be corrected if I am incorrect.
How much light do you need? Is this something that you can handle with a motion sensor, dual PAR38 type light?
Do you have room in your main panel for an additional circuit if you need a lot more light?
If you do not have anymore room, and you need a large amount of circuits, then you may need to install a subpanel. Sub's aren't typically the first option unless this condition is met.
Hope that helps.
wikkie650 is offline   Reply With Quote
Old 10-29-2010, 06:14 AM   #3
Yes, I have run out of room on the main board
I plan to use a permenent version, similar to these...4 or maybe more
http://northerntool.digby.com/shops/...7&vendorId=110
They're 500 watt each
Anything else?
Old 10-29-2010, 09:57 AM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
then you would need to either install a panel with more circuits as your main panel or add a subpanel.
Old 10-29-2010, 01:39 PM   #5
dont want to sound mean but i think i already established this
I would like a basic description on installing a subpanel
thanks
Old 10-29-2010, 02:00 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 554
http://www.dropshots.com/stubbie4#al...0Installations
This should explain everything.
Old 10-29-2010, 02:07 PM   #7
ok thank you
Old 10-29-2010, 03:42 PM   #8
nap
You talking to me?
nap's Avatar
thanks
if you notice, I also listed an option that would remedy your situation without installing a subpanel but it will be a cold day in hell before I offer you any advice on how to do it.
you didn't ask how to install a subpanel, you asked if you needed one
The Following User Says Thank You to nap For This Useful Post:
Davester (10-31-2010)
Old 10-31-2010, 07:19 AM   #9
Does anyone else want to cooperate and help me out?
I'll ask the question very simply so that everyone understands.
What are the basic steps to installing a subpanel?
I understand that 2 wires must be run from my original box and connected to the sub to the "main lugs" (right?) and then a 3rd, ground wire to neutrilize the system. What else?
Oh and these are the lights I wish to use, if it makes a diffrence
http://www.homedepot.com/Outdoors-Ou...atalogId=10053
Old 10-31-2010, 07:50 AM   #10
Master Electrician
Rewards Points: 3,920
Four wires installed by a qualified electrician, otherwisw you'll be doing a lot more worrying as your first post stated.
brric is online now   Reply With Quote
Old 10-31-2010, 07:56 AM   #11
What your saying is that I require someone trained and who actually knows what they are doing?
Old 10-31-2010, 08:11 AM   #12
the Musigician
DangerMouse's Avatar
If you pull a PERMIT and have your work inspected and approved, no.
If you are uncomfortable working with electricity, then yes, please do call an electrician.
However...with help from the (normally) great guys here, this is an easily done project that will pass inspection.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
Old 10-31-2010, 10:15 AM   #13
I am not uncontrollable but I have good realationship with my local hardware store friends. Thanks for all your help
Newbie with some questions about windows docnd Building & Construction 5 08-18-2010 08:08 AM
Newbie with questions about a 4 ton rheem nissan4x4 HVAC 4 05-24-2010 11:53 PM
Newbie with 1st Home New Problems New Questions Lightning#88 Introductions 0 12-15-2009 05:49 PM
Lots of newbie Concrete Fountain Questions! wps74 Building & Construction 18 08-19-2009 02:08 PM
More painting questions from a newbie. Tab1975 Painting 5 04-24-2009 11:13 PM
