Old 12-27-2010, 06:29 AM   #1
Newbie question on grounding
I'm just learning about home electricity, and have read about the importance of grounding.
Looking around the house, the following have 2-prong plugs:
all floor and table lamps
toaster
coffee maker
mixers
tv and radio
fans
Why would all of the above be manufactured without a grounded plug?
The grounded items in the house are:
washing machine
microwave
refrigerator
bw777 is offline   Reply With Quote
Old 12-27-2010, 06:55 AM   #2
Most small appliances, lights, etc., have two prong polaraized plugs(neutral pin larger). They are usually insulated or isolated internally, so no need for a ground conductor. Those appliances that require a ground prong for certification approval, have one.
Old 12-27-2010, 09:07 AM   #3
joed's Avatar
The outside case is either plastic or double insulated so there is no chance of it becoming energized. Therefore no ground pin is required.
Do not PM with questions that can be asked in a forum. I will not respond.
New Roof Question From A Newbie Marc48 Roofing 5 04-16-2010 07:16 PM
4 pin dryer to 3 pin (grounding question)? nadazip Electrical 6 07-06-2009 11:00 PM
Newbie with a framing question. 737Pilot Building & Construction 19 03-21-2008 07:53 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 05:11 PM
Newbie Question bjp Introductions 2 10-09-2006 03:37 AM
