Newbie - Fixing A Switch And Adding A Light - Electrical - DIY Chatroom Home Improvement Forum
Old 09-14-2011, 03:19 PM   #1
Newbie - fixing a switch and adding a light
Hello -
I am replacing a dead switch - and I want to attach a new light to it.
the switch is a 3 way switch. It is at the dead end of the switch (meaning it is only one set of wires) I want to add a light to this switch so that when the garage lights are on, the outside light is on too.
The current switch has a red, black and white wire.
My current light is wired with a ground, white and black.
How would I set this up? do I need to purchase another switch and run 2 switchs? Am I making any sense?
I am thinking of connecting the blacks together, and leaving the red alone, and the whites together. and connecting the grounds. and using one wire to connect to the switch.
Am I totally confused?
YES I know to turn off the juice at the breaker!
Thanks in advance.
telechick is offline   Reply With Quote
Old 09-14-2011, 06:16 PM   #2
joed's Avatar
Rewards Points: 12,878
Your new light needs to connect into the existing light. You can not connect to this switch. You do not have the enough wires for this to work. You might be able to connect at the other switch but you can for sure connect at the existing light.
Old 09-14-2011, 06:29 PM   #3
O! I didn't think about that! Crap now I need to rewire as it's too short. O well- thanks! Does it matter which light I wire it to? There are 2 in the garage.
Old 09-14-2011, 08:59 PM   #4
joed's Avatar
Does not matter. Any fixture controlled by the switches can be used s the source for the new light.
Adding a light between a light switch and the receptacle it controls jej2csi Electrical 3 11-24-2010 07:06 AM
adding second light from a switch agsurfer Electrical 3 09-10-2010 12:01 PM
new light and switch problem please help rebelbull Electrical 1 10-02-2009 06:39 AM
HELP.. trouble adding light to single pole switch RickDel Electrical 13 09-09-2009 10:18 PM
Adding second light switch to an existing light TexasEd Electrical 7 08-15-2008 06:22 PM
