New York City Electrical Codes For Window Air-conditioners - Electrical - DIY Chatroom Home Improvement Forum
Old 03-26-2008, 06:35 AM   #1
Question
New York City Electrical codes for Window Air-conditioners
I just rented a small one room office in Manhattan (central New York City.) Can someone confirm that the local electrical code requires a separate electircal line with its own breaker for a window air-conditioner? Thank you.
lacrossedad is offline   Reply With Quote
Old 03-26-2008, 07:15 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,882
How big is this A/C?
More than a 12k BTU and it's likely regardless of your area.
Speedy Petey is online now   Reply With Quote
Old 03-26-2008, 10:15 AM   #3
Rewards Points: 928
Electrical codes govern the installation of electrical work, not the installation of a portable appliance. Most likely, any office in NYC will be wired with a minimum #12 awg, 20a circuit.
There is no NYC electrical code that requires an a/c outlet in a commercial space.
LawnGuyLandSparky is online now   Reply With Quote
Old 03-26-2008, 10:22 AM   #4
NYC electic codes on window airconditioners
Thanks for the reply. Although the airconditioner came with the office, I am guessing that it is about 12,000 BTU, the office is just shy of 300 sq feet with 1 large window facing west and 3 large windows facing north. I have to check the breaker box to confirm that the airconditioner is on a separate line. Thanks for your input. Is the BTU output usually marked on the spec plate of a window unit?
Old 03-26-2008, 04:00 PM   #5
Rewards Points: 928
Yes, but more importantly the wattage or amperage will be listed. Usually commercial leases spell out the electrical power available, does yours?
Old 03-26-2008, 05:27 PM   #6
dad, you are asking this for a reason. What is that reason?
Old 03-27-2008, 01:15 PM   #7
I just signed a lease for a small office in Manhattan which has a window airconditioner. When I first looked at it, it appeared to be plugged into a regular wall outlet that did not look like a dedicated line. I requested that the landlord put in two more regular lines plus a deducated airconditioner line (plus paint the place, etc). After our communication yesterday, I went back to look. I see he put in a large conduit with a few outlets including the airconditioner. We went to the power pannel and they showed me the new dedicated airconditioner breaker and the other breakers. Looks like I'm set.
Electrical Permits, Codes and Inspections? realeyz Electrical 1 12-28-2005 09:32 AM
