-   -   New York City Electrical codes for Window Air-conditioners (http://www.diychatroom.com/f18/new-york-city-electrical-codes-window-air-conditioners-19023/)
lacrossedad 03-26-2008 05:35 AM
I just rented a small one room office in Manhattan (central New York City.) Can someone confirm that the local electrical code requires a separate electircal line with its own breaker for a window air-conditioner? Thank you.
Speedy Petey 03-26-2008 06:15 AM
How big is this A/C?
More than a 12k BTU and it's likely regardless of your area.
LawnGuyLandSparky 03-26-2008 09:15 AM
Electrical codes govern the installation of electrical work, not the installation of a portable appliance. Most likely, any office in NYC will be wired with a minimum #12 awg, 20a circuit.
There is no NYC electrical code that requires an a/c outlet in a commercial space.
lacrossedad 03-26-2008 09:22 AM
NYC electic codes on window airconditioners
Thanks for the reply. Although the airconditioner came with the office, I am guessing that it is about 12,000 BTU, the office is just shy of 300 sq feet with 1 large window facing west and 3 large windows facing north. I have to check the breaker box to confirm that the airconditioner is on a separate line. Thanks for your input. Is the BTU output usually marked on the spec plate of a window unit?
LawnGuyLandSparky 03-26-2008 03:00 PM
Yes, but more importantly the wattage or amperage will be listed. Usually commercial leases spell out the electrical power available, does yours?
Speedy Petey 03-26-2008 04:27 PM
dad, you are asking this for a reason. What is that reason?
lacrossedad 03-27-2008 12:15 PM
I just signed a lease for a small office in Manhattan which has a window airconditioner. When I first looked at it, it appeared to be plugged into a regular wall outlet that did not look like a dedicated line. I requested that the landlord put in two more regular lines plus a deducated airconditioner line (plus paint the place, etc). After our communication yesterday, I went back to look. I see he put in a large conduit with a few outlets including the airconditioner. We went to the power pannel and they showed me the new dedicated airconditioner breaker and the other breakers. Looks like I'm set.
