New Wiring/circuit OK? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-31-2011, 05:21 PM   #1
New wiring/circuit OK?
I'm doing a little remodeling where I'm moving the location of my kitchen to another part of the house and the old location is going to be a new den/office.
In my new kitchen I have 12 recessed cans that can handle 150 watts per can, I have 7 recessed cans for an adjacent hallway, 3 cans for a buffet area, a 150 watt dining room light fixture, a 150 watt Den light fixture with 5 15 amp outlets.
My circuit plan is:
9 kitchen lights on 1 15 amp circuit
3 kitchen lights, 3 buffet lights and dining room light 1 amp circuit
7 hallway lights, den light and 5 outlets on 1 15 amp circuit - arc fault
With:
two 20 amp counter top kitchen circuits
15 amp dishwasher circuit
15 amp garbage disposal circuit
20 amp fridge circuit
20 amp microwave circuit
20 amp dining room circuit - arc fault
Does this seem OK? Any suggestions?
twalber is offline   Reply With Quote
Old 07-31-2011, 06:41 PM   #2
Rewards Points: 6,652
Dishwasher & disposall can be on the same 15 amp circuit. As for lighting, you could probably do one 20 amp circuit if going with CFL's. The really big question is, where do you live (U.S. state, or Canadian providence).
Old 07-31-2011, 07:00 PM   #3
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
What is the size of the disposal? What is the nameplate info for the D/W? Frig can be on it's own 15 amp dedicated circuit. Disposal, D/W and frig do not require GFI protection.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 08-01-2011, 05:50 AM   #4
RST
DIY Homeowner
Rewards Points: 150
I think I've heard that some refrigerators are now calling for 20A circuit? Probably only high end ones, I suppose.
Don't forget a circuit for the stove.
RST
RST is offline   Reply With Quote
Old 08-01-2011, 07:29 AM   #5
RST, stove can come off of one of the branch circuits for either the counter, or in my case, the baseboard outlet branch. If anything, yes, put in the possibility of having an electric appliance there helps, especially in future proofing.
Old 08-01-2011, 10:18 AM   #6
RST
DIY Homeowner
Rewards Points: 150
Yeah, sorry, I assumed an electric stove. Not normally up as early as I was today.
Old 08-01-2011, 11:08 AM   #7
Just call me Andrew
Rewards Points: 1,020
Lighting circuits are normally sized based on the max wattage of the fixtures, not based on what type of bulb you use. What he (or the next owner) decides not to use CFLs in the future?
Andrew
secutanudu is offline   Reply With Quote
Old 08-01-2011, 11:16 AM   #8
CFL's are the future.
Old 08-01-2011, 11:18 AM   #9
Just call me Andrew
If you say so!
Andrew
Old 08-01-2011, 11:52 AM   #10
Originally Posted by secutanudu View Post
If you say so!
The government says so. I use them, because in the long term they are cheaper, and my power bills are a whole lot lower, than if I was still using incandescents. LED's are the next generation, and those will even be more power conserving, and over time, older circuits will be overkill for the little amount of power those type of bulbs use.
Old 08-01-2011, 12:34 PM   #11
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Check w/ your town too. Dishwasher and disposal can share a circuit but my town has a requirement that they need to be plug-in in order to do so. If hardwired, they must have a circuit each.
CoconutPete is offline   Reply With Quote
Old 08-01-2011, 12:38 PM   #12
Just call me Andrew
To each their own, I guess. I can't stand the light that CFLs or LEDs put out, and I'll continue to use incandescents in spite of the cost.
Andrew
Old 08-01-2011, 12:50 PM   #13
Give them time, and they will get better. CFL's have come a long way in just five years, LED's will get better over time.
