#1 |
new wires
can I run 2- #12, and 4 - #8 wires in a 1/2" conduit? 1 hot and 1 neutral #12, 2 hot ,1 neutral, and 1 ground #8? I am changing stove from gas to electric.
#2 |
Average Joe/ex-Navy IC3
new wires
An electric stove only needs a 4-wire hookup, not both 120 & 240v. Are you planning on installing a microwave hood also?
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
#3 |
new wires
there is a countertop microwave plugged into the existing outlet, so I was going to keep it live. I may be able to feed it from a different source
#4 |
new wires
Makes it a lot clearer now. How many SABC (Small Appliance Branch Circuits) do you have already in the kitchen? Also, update with your location, and if this is a home, apt., condo, manufactured/mobile home.
#5 |
new wires
It is a single family home in Chicago, IL 1925 to 1930. The Kitchen has several circuits, but they will need to be updated when the complete kitchen remodel takes place. now we are just installing the new stove during a basement laundry room project, just under the kitchen. I am trying to get as much done for the future work as possible, I don't want to have to change the pipe and wiring twice. Thanks
#6 |
Master Electrician
new wires |
#7 |
new wires
Good move Turbo, doing it while you can. As for the two runs, may want to look at what you have now, and then draw out a plan, so you have an idea how things are going to turn out. Especially if you have to submit for a permit, being Chicago and all.
| Display Modes | |
| D 3 number 12 wires equal one number 8 wire? | Uncle Wayne | Electrical | 3 | 01-26-2011 09:00 PM |
| if there are red white green and black wires coming out of your walls like everywhere | cray331 | Electrical | 3 | 01-17-2011 01:56 PM |
| 240v conduit with different gauge wires... | Biospot | Electrical | 7 | 12-14-2010 08:07 PM |
| Removing wall with wires in it | jboswald | Electrical | 11 | 11-29-2009 03:55 PM |
| Three hot wires coming into a receptacle? | Jeff DIY | Electrical | 10 | 10-07-2009 02:35 PM |
