New Wire In Old Cable? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-24-2008, 10:13 PM   #1
New wire in old cable?
Hi;
Has anyone had any luck with pulling new THNN wires through an old BX?
It would be a way to avoid having to open walls/ceilings to replace the cable itself.
The existing BX is #14. I would try to pull three (black, white, green) THNN wires for the lights in the ceilings where access from upstairs is not possible.
I would imagine that this could work if there are no sharp (RA) bends in the cable. I often see RA BX clamps at the boxes, so these would be very difficult unless I can get the old box out.
Then, if I can get the box out, I might as well pull a whole new cable, right?
FW
fw2007 is offline   Reply With Quote
Old 06-24-2008, 10:34 PM   #2
Power Gen/RS Engineer
Rewards Points: 566
Good luck. I've never before heard of anyone trying this so I wouldn't even know where to look in the NEC regarding its legality. You would have hells own time removing the old wires (esp. if they are cloth covered). It can be difficult to fish wires through a piece of 1/2" greenfield (which has a considerably larger ID) with a few bends in it. I think that you're better bet would be to try connecting new MC cable to the old BX (splicing the wires together) and using the BX to pull in the new armored cable. There is no way in "H" that this will work if there is even one strap on the old stuff though.
Best bet is to bite the bullet and pull in/fish new MC cable. If you have attic/basement access, this can be rather easy actually.
Take care,
Jimmy
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 06-24-2008, 10:49 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
it's not legal. BX is made as a cable and it is not legal to alter it. Altering it would make it not BX anymore.
On top of that, what you essentially are doing is using the metal sheath as flexible metallic conduit, which is not allowed in sizes under 1/2 except in a very few applications.
Old 06-25-2008, 08:18 AM   #4
Thanks for your advice. I read about doing this somewhere, and was interested to find whether anyone had actually done it. I'm not really surprised that it's not legal.
I'll have to find where I read it, and send a comment to the author.
FW
Old 06-25-2008, 11:24 AM   #5
Rewards Points: 64
Follow naps instructions and warnings. He is absolutely correct.
J. V. is online now   Reply With Quote
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 02:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 10:00 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
I really need help! POOK Electrical 34 04-20-2007 08:01 PM
