New Well Pump / Genorator Watts - Electrical - DIY Chatroom Home Improvement Forum
Old 11-01-2012, 03:48 PM   #1
New well pump / Genorator watts
I just installed a new well pump. It is a 3/4 hp 2 wire pump. I have a normal two hundred amp service coming in my house. The circuit breaker for the pump is a 20 amp. When the pump starts up each wire pulls 150 amps on my meter and runs at 7 amps. What size genorator do I need or I my amp clamp laying to me?
pbaehr77 is offline   Reply With Quote
Old 11-01-2012, 07:26 PM   #2
Rewards Points: 130
The breaker was sized to the load and it is 20 amps. Now why would you need to concern yourself with inrush current? Are you tripping the 20 amp breaker now?
Old 11-01-2012, 09:15 PM   #3
Watts= amps x volts
20 amps x 220 volts = 4400 Watts
A 5000 watt genny should run the well pump with no prob.
SK
southernkilowat is offline   Reply With Quote
Old 11-01-2012, 09:55 PM   #4
Thanks very much was looking at a 5000 surge but going to step it up to a 7000 continues 9000 surge. Thanks agine
Old 11-01-2012, 10:10 PM   #5
Did you miss the two times that he said he was looking to size a generator to power the well pump??
Hundred is offline   Reply With Quote
ejector pump suddenly tripping gfi lilargie Electrical 4 04-24-2012 05:15 PM
Well pump trips breaker at start, but then starts when breaker reset J. David Electrical 34 02-25-2012 11:23 AM
Drainage under packaged heat pump salonica HVAC 18 12-25-2011 07:07 AM
Intermittent submersible pump fault esquilax Electrical 5 09-30-2011 03:56 AM
Shallow well pump issues, spinnb7 Landscaping & Lawn Care 1 04-13-2010 01:04 PM
