New Under Ground 220 Electric Wire - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-20-2009, 05:52 PM   #16
DIYer
Originally Posted by chris75 View Post
It makes no sense what so ever, do you think 120 is more safe or less safe than 240?
I don't know, ask the people who wrote that exception into the NEC that limits it to 120v at 12 inches.
My point is that the inspector isn't entirely off the wall with this.
Gigs is offline   Reply With Quote
Old 01-20-2009, 06:14 PM   #17
Electrician
Sure he his, check out note #4 under 300.5
chris75 is offline   Reply With Quote
Old 01-20-2009, 06:26 PM   #18
DIYer
Right, that's the note that allows UF at 12 inches provided it's 120volts 20 or 15 amp and GFCI.
I don't think it's a stretch to disallow two 120v on different phases that are buried in the same trench at 12 inch depth. I could see an inspector going either way on that one. I definitely don't think it's clear cut enough to dismiss the inspector out of hand for deciding that two 120v on different phases is the same as 240v.
Old 01-20-2009, 06:46 PM   #19
Rewards Points: 2,350
If this were a 240 V circuit, I would agree. But the fact is they are two different circuits, each GFCI protected. And there is no guarantee that each circuit is on a different phase. They could just as easily be on the same leg of the panel, and thus 0 V between them.
I would say that the inspector is totally baseless with this call, IMHO.
Old 01-20-2009, 10:01 PM   #20
Idiot Emeritus
Rewards Points: 1,492
When using direct-burial cables, you can put all of them in the same ditch, wrap them around each other, tie them in knots, etc. Just don't damage the insulation with shovels, rocks, heavy equipment, etc.
They need to be in close proximity to each other, and where they emerge from the ground they need to be in conduit. The bottom of this conduit needs to be at least 18" below finish grade.
The minimum depth is 24", except where they are buried under a driveway, or under concrete. 18" is the minimum here. Table 300.5 of the code governs underground installations.
Rob
micromind is offline   Reply With Quote
Old 01-20-2009, 10:17 PM   #21
Licensed electrician
Rewards Points: 1,880
Are you running both of these circuits to an outbuilding or do you have 2 loads that are both outside?
Old 01-20-2009, 10:18 PM   #22
DIYer
Good catch.
Old 01-20-2009, 10:28 PM   #23
Electrician
ctsmiths's Avatar
Rewards Points: 150
Why would that matter?
ctsmiths is offline   Reply With Quote
Old 01-21-2009, 01:09 AM   #24
Because you can only have one feeder or branch circuit to a detached structure.
Old 01-21-2009, 10:07 AM   #25
Electrician
ctsmiths's Avatar
Rewards Points: 150
But how does that affect them being in the same trench?
Old 01-21-2009, 10:16 AM   #26
Because if they were going to the same structure it would be a problem.
jerryh3 is offline   Reply With Quote
Old 01-21-2009, 10:21 AM   #27
Licensed Pro
Originally Posted by Scuba_Dave View Post
I wasn't going to argue with him
When I 1st called & said I was running UF 20a 12" down that would be GFCI protected, 1st they said I couldn't do that. Then I quoted the specific code out of NEC. They said they would have to call me back
They called back & said I could run 1 line per trench
If I ran (2) circuits they said someone digging could hit 240v
Waddya gonna do
It would be interesting to ask this inspector how you should deal with a 120/240V feeder to an outbuilding or a 240V line to a well pump.
Old 01-21-2009, 10:28 AM   #28
Electrician
ctsmiths's Avatar
Rewards Points: 150
Only once they hit the structure, the guys question was can they be in the same trench, not can you run two circuts to a structure. So I dont get why were talking about this. Lots of assuming going on.
Old 01-21-2009, 10:39 AM   #29
That's why this question was asked:
There was no assuming going on.
Old 01-21-2009, 11:06 AM   #30
Both of my circuits were for the yard - terminated at an outlet on a post. I did run 60a feed to my pool cabana for a sub - but that was in conduit. But yeah, buried 240v feed you would have the same issue if you hit both hots with a shovel
But I think that would need to be at 18" depth?
To add, these circuits were run along the side of a garden. So he may have used that fact to reach his decision. Since most gardens can be dug up more then a yard
New Stove, old wires - 2 wire vs 3 wire DIYGST Electrical 22 03-02-2009 04:13 PM
Will reverse polarity trip breaker?? Duane 70 Electrical 60 12-05-2008 10:18 PM
Paint Ground Wire kevin0 Electrical 4 02-10-2008 10:39 PM
smoke alarm - ground wire Potomac101 Electrical 7 02-06-2008 07:25 AM
Can you wire a 3-way circuit with 2 wire + ground mnyman2003 Electrical 8 12-04-2007 08:23 AM
