New Under Ground 220 Electric Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 01-20-2009, 10:52 AM   #1
new under ground 220 electric wire
can 2- 220 electrical wires be installed in same ditch and be touching or do they need not to touch before i cover with dirt.
eddie brown is offline   Reply With Quote
Old 01-20-2009, 11:03 AM   #2
Electrician
ctsmiths's Avatar
Rewards Points: 150
Are the cables Direct Burial type cable?
ctsmiths is offline   Reply With Quote
Old 01-20-2009, 11:05 AM   #3
i need to install two seperate 220 underground wiring need to know if i need seperate trenches or can these wires touch in the same trench . wiring is desinged for underground .
Old 01-20-2009, 11:06 AM   #4
Electrician
ctsmiths's Avatar
Rewards Points: 150
And what are you feeding with them?
Old 01-20-2009, 11:08 AM   #5
yes cable is !
Old 01-20-2009, 11:12 AM   #6
Electrician
ctsmiths's Avatar
Rewards Points: 150
OK. what are the 220 cables feeding?
Old 01-20-2009, 11:13 AM   #7
30 amp
Old 01-20-2009, 11:21 AM   #8
Electrician
ctsmiths's Avatar
Rewards Points: 150
If they are for the same circut they have to be in close proximity, ( like if you use both cables to feed one piece of equipment) ,if not they don't.
Old 01-20-2009, 12:35 PM   #9
My Inspector wouldn't even allow (2) 120v 20a UF circuits protected by GFCI before going in the trench to share the same trench
I'd check with your Inspector 1st
Old 01-20-2009, 04:11 PM   #10
Electrician
What crack pipe is he on?
chris75 is offline   Reply With Quote
Old 01-20-2009, 04:21 PM   #11
Wow...I bet he doesn't allow romex fished through walls.
rgsgww is offline   Reply With Quote
Old 01-20-2009, 06:32 PM   #12
I wasn't going to argue with him
When I 1st called & said I was running UF 20a 12" down that would be GFCI protected, 1st they said I couldn't do that. Then I quoted the specific code out of NEC. They said they would have to call me back
They called back & said I could run 1 line per trench
If I ran (2) circuits they said someone digging could hit 240v
Waddya gonna do
Old 01-20-2009, 06:35 PM   #13
Electrician
Waddya gonna do
Yeah... tell them to educate themselves, Perfect example why some people dont get permits, the people inspecting are no smarter than the guy doing the install.
Old 01-20-2009, 06:38 PM   #14
DIYer
Well that makes some sense... That exception to allow UF at 12 inches specifically limits it to 120v 15 or 20 amps GFCI. So it's not too off the wall. At 24 inches he would have probably allowed you to fill the trench up with as many as you wanted.
Gigs is offline   Reply With Quote
Old 01-20-2009, 06:42 PM   #15
Electrician
It makes no sense what so ever, do you think 120 is more safe or less safe than 240?
New Stove, old wires - 2 wire vs 3 wire DIYGST Electrical 22 03-02-2009 05:13 PM
Will reverse polarity trip breaker?? Duane 70 Electrical 60 12-05-2008 11:18 PM
Paint Ground Wire kevin0 Electrical 4 02-10-2008 11:39 PM
smoke alarm - ground wire Potomac101 Electrical 7 02-06-2008 08:25 AM
Can you wire a 3-way circuit with 2 wire + ground mnyman2003 Electrical 8 12-04-2007 09:23 AM
