New Thred Main Loose At Bus Bar - Electrical - DIY Chatroom Home Improvement Forum
Old 11-06-2013, 07:59 PM   #1
New thred main loose at bus bar
OK..SO I GOT A LOT OF NO's ABOUT USEING THE NO OX
I had a little sizzle where the main breaker tab bolts to the bus bar...I tightened it down , its ok now..because it was not a bad arcing ..can I clean..sand and retighten? what about the minor voids where the arcing accrued.. i was thinking that the no ox would just fill in the voids...
or is it unnecessary...thank all of you for your reply's...richard
richard444 is offline   Reply With Quote
Old 11-06-2013, 08:02 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
No Ox isn't a type of Bondo. If the buss bar is showing pitting from the arcing, the panel needs to be replaced. If you were a customer, I wouldn't even mention repairing the buss...replacement or I wouldn't put my name on it.
The Following 4 Users Say Thank You to k_buz For This Useful Post:
Philly Master (11-07-2013), richard444 (11-06-2013), Speedy Petey (11-08-2013), stickboy1375 (11-06-2013)
Old 11-07-2013, 02:20 AM   #3
Rewards Points: 774
THe best option is to utilize a burnishing tool LIGHTLY removing the high spots.
Most good motor shops will sell them or a very fine paper on a small stick to ease in removing the high spots, watch for the dust you create as this is conductive.
If it appears there is metal fatigue, you should just bite the bullet and replace the panel guts. Metal fatigue will show id discoloration of the bus and hardware due to heat.
Know A Little is offline   Reply With Quote
Old 11-08-2013, 12:57 AM   #4
Rewards Points: 366
if there is just a few small pits , i wouldn't worry too much. but there is a lot, then a new panel is called for!
circuitman is online now   Reply With Quote
Old 11-08-2013, 05:42 AM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,972
Even for the main breaker???
Sorry, but I strongly disagree. I am with Kbuz, replacement is the ONLY option, because it WILL happen again.
Old 11-08-2013, 05:45 AM   #6
Rewards Points: 774
Depending on the extent of the damage this issue can be addressed, if handled properly. But as I have noted the extent of the pitting and the possibility of metal fatigue needs to be carefully looked at.
Old 11-08-2013, 10:19 AM   #7
Rewards Points: 366
agreed! if there is no discoloration on the metal & it has not been prolonged, which may not be known, it may be able to still be used. but when in doubt to be safe the best way is to replace.
The Following User Says Thank You to circuitman For This Useful Post:
Know A Little (11-08-2013)
Old 11-08-2013, 10:44 AM   #8
Rewards Points: 774
Actually for the price of the panel which is minimal I'd replace it
main loose at the bus bar richard444 Electrical 32 11-07-2013 02:14 AM
Main Circuit Breaker Question vladmir1111 Electrical 2 08-20-2011 08:15 PM
main lug or main breaker kenmore Electrical 14 06-18-2011 11:13 AM
DWV remodel. Can I do this with my main? antalamo Plumbing 0 03-19-2011 09:29 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
