New Thermostat Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 12-18-2010, 06:29 PM   #1
new thermostat wiring
I just installed a new thermostat, I put the red wire to the R I put the white to the W, blue to the B and green to the G it is a honeywell CT87N I tried it on heat and the air cond, went on. what did I do wrong
meyers is offline   Reply With Quote
Old 12-18-2010, 06:46 PM   #2
Electrical Contractor
kbsparky's Avatar
DISCONNECT that blue wire. See if it works.
Do you have a yellow wire present?
-KB
Old 12-19-2010, 08:13 PM   #3
Rewards Points: 494
see:
http://highperformancehvac.com/hvac-...at-color-chart
diyorpay is offline   Reply With Quote
Old 12-19-2010, 08:24 PM   #4
Rewards Points: 1,192
program wrong? read the o/r instructions.
bobelectric is offline   Reply With Quote
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Unexpected wiring found on existing thermostat mportobello HVAC 12 03-30-2010 06:11 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Thermostat wiring jetmanaz HVAC 1 08-09-2009 07:13 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 07:40 AM
