New Therm For Electric Heat - Electrical - DIY Chatroom Home Improvement Forum
Old 01-04-2010, 12:35 PM   #1
New therm for electric heat
I want to replace my thermostats for my 110V electric heat. individual per room. Old one's are the round knob looking ones. So i open up the guy and take a peek at the wires and that's where i have the problem. there are 2 blk, (twisted together) 2 white (twisted together), a single black and a single white. Total of 6 wires (4 if you count the twisted ones as one), the programmable thermostat....only has 2 blk.
Only one lowes carries / says its for 110 electric / house is relatively new...3 yrs old.
Any assistance would be great.
vzx34 is offline   Reply With Quote
Old 01-04-2010, 01:25 PM   #2
Can you take a picture and post it?
How do you know it is 110 volts?
Billy_Bob is offline   Reply With Quote
Old 01-04-2010, 01:51 PM   #3
You are correct that is kind of an assumption, could be 220 right? I will take a picture tonight and post tomorrow, also i'll take a pic of the breaker in the event that helps.
Thanks for the reply, i will post tomorrow.
Old 01-04-2010, 04:38 PM   #4
The best so far as voltage and wattage is to look on the "nameplate" (label) on the heater. If more than one heater on the same thermostat, look at the labels on each heater.
There are 120 volt thermostats which have two wires. And 240 volt thermostats which have 4 wires.
The breaker for a 120 volt heater would be a single breaker. The breaker for a 240 volt heater would be two breakers connected together.
And thermostats will be rated to handle a certain wattage.
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 07:15 AM
programmable line voltage therm for fan heat nykije HVAC 1 11-18-2009 10:51 PM
baseboard heat, new therm burning wires?? wont' shut off Krazecon HVAC 11 10-23-2009 05:50 AM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 04:05 PM
