-   -   New/Temp service disconnects question (http://www.diychatroom.com/f18/new-temp-service-disconnects-question-98050/)
boschblue 03-11-2011 02:27 PM
Does the following seem legal / reasonable for new construction on a large rural lot?
Power comes in via overhead line to a "yard pole" which currently only has an empty meter socket. My house will be built about 70 feet away from the pole, and I may build another garage or shed or barn on the lot sometime in the future, so it's handy to have the yard pole as a central power distribution point.
My idea is to install an outdoor 200A main breaker at the pole to serve as the main disconnect, which would be required due to distance to the house anyway. I would also like to have a smaller "temporary construction" outdoor box which has two 20A GFCI breakers and covered-in-use outlets. Would it make sense to install the 200A main breaker at the same time I install the "temporary construction" box so it's there long before construction even begins on the house?
boschblue 03-12-2011 09:44 AM
I will rephrase my long rambling question above: My new meter socket is located on a pole on my new rural lot. I will eventually be building a house and shed. For now I want some temporary 20A outlets on the pole. Can I / Should I have a 200A main breaker in its own outdoor box, followed by indivdual 20A breakers in their own outdoor box which would feed GFCI covered-in-use outlets? The 200A main would probably be overkill but I'm thinking about a minimal number of disconnects and a simpler way of connecting the house once built.
code_compliant 03-12-2011 10:24 AM
http://i256.photobucket.com/albums/h...eesWork039.jpg
Install a meter main. These can be fed overhead or underground. The bottom portion has a 200 amp main breaker, feed thru lugs for your house and 6 breaker spaces for other loads.
Doubtful you'll find it at a box store so contact a wholesaler.
J. V. 03-12-2011 11:39 AM
They sell them at Home depot and Lowes around here and they are inexpensive. I saw one (200 amp) at Home Depot for around $100.00. Meter main is the way to go. Especially since this is a pedestal service.
Remember you can only take one 4 wire feeder or branch circuit to each structure. One for the house and one for an outbuilding or other structure you may have.
You will be able to use main lug panels for the house and other structure.
code_compliant 03-12-2011 12:41 PM
[quote=J. They sell them at Home depot and Lowes around here and they are inexpensive. I saw one (200 amp) at Home Depot for around $100.00.
You will be able to use main lug panels for the house and other structure.[/quote]
At $100 I'm not sure you have the right panel. Got a part #?. If you use an MLO panel you'll need a seperate service disconnect for each structure even though your need for overcurrent protection is satisfied. Put simply just use Main breaker panel.
davido30093 03-12-2011 01:10 PM
Like this one?
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
