#1 |
New T8 Light Fixture doesn't work
I had a dying T12 light fixture and since you cant buy new T12 ballasts, I just replaced it with a new 4 Bulb T8 Light Fixture.
Unfortunately this light fixture doesnt work. I hooked up my voltage meter to it and it shows 116 volts at the line going into it. Would 4 volts off cause the light not to fire? Any ideas to try and get it to work? Edit: In a 4 bulb fixture I do only have 2 bulbs in it. Is that OK, or do I need to have all 4 in? Last edited by tunaman; 11-03-2012 at 08:34 PM. |
#2 |
Try it with all 4 lamps. The T8 fixtures we use do allow removal of lamps. I'm not sure if that is true of all of them.
Another issue could be grounding. Some fixtures require a ground to fire the tube properly.
Do not PM with questions that can be asked in a forum. I will not respond. |
#3 |
There is a green ground screw in the frame (not hooked to the ballast) but on the fixture I took out it was not hooked up so figured this one would be the same. The instructions dont even mention the ground. There was just black and white wires coming in to the original fixture. There is a ground screwed in to the junction box about 12 feet away.
#4 |
Pure Genius
Put all lamps in. Some fixtures require all lamps to fire
#5 |
Check that it has a 120v ballast inside.
#6 |
Licensed electrician
Check the wiring going to the sockets. there is a good chance it needs to be changed. A diagram will be on the ballast.
Answers based on the National Electrical Code. Local amendments may apply. Check with your local building officials. |
#7 |
I will get 2 more bulbs tomorrow. Im hoping that is the problem. Yes it says in big letters 120 vollts. I know I wired it correctly. I took one look at the wiring and it is obvious. All the prewired wiring is color coded and cut to just the right length. 2 long yellows for the ends, and a red and blue for the middle. And for the power black to black and white to white. I took this fixture out of the box new today.
Thanks guys, I knew I wired it right but I have never really done lighting before so wasnt sure if there was something I might have been missing. If adding 2 bulbs doesnt work tomorrow, im replacing the fixture. |
#8 |
" Euro " electrician
What the ballast part number is on stamped on it so the reason why I can able indentify if you have rapid start or instat start ballast.
Note the rapid start they always wired in series of pairs of bulbs so you will need two bulbs to get one set lit up. The instat start verison will useally wired in either way but most case in parallel mode so any numbers of lamp will get it running. Again post the number and we will go from there. Merci, Marc
The answer will be based on NEC ( National Electrical code ) or CEC ( Cananda Electrical code ) or ECF ( Electrique Code France ) |
#9 |
ap rc 432ip 120 - 1 it is labeled instant start ballast.
#10 |
Parallel connection.
Second thing is check the tombstone to make sure the connection is good some case the conductors can come loose from factory which I have see it once a while. You will need 4 lamps to get this light up first time. And try to switch the red et bleu socket around some case it will work. If that fail to light up then take a test lamp or use the tempory outdoor pigtail light socket and use with 60 watt bulb and hook it up tempory to make sure you actually have good source due some of the DVM ( digial voltmeter ) don't actually put a load on espcally with a bad connection which it will show up. If your test light don't come on then you have issue with supply you may want to check the connection and splices at the junction box ditto with switch box if the netural is there. Merci, Marc
#11 |
My connections are all solid. I double checked them when it wasnt working. I have good power all the way up to the leads for the fixture. I bet 2 more bulbs will work.
#12 |
I went and got 2 bulbs today and nope, no go. Put in all 4 bulbs and I do not have light. Im not sure what I could have done wrong but I guess maybe fixture bad.
#13 |
I think you are overlooking the grounding issue. Some lamps may not start with the ground missing.
Your instructions (step 3) tell you to connect the ground. They mention the ground, before the supply wires. Maybe you should give Lithonia a call and see if they can help you. |
#14 |
I added a ground wire, just from the ground screw to a nearby junction box with a ground wire and no go.
#15 |
Is the other junction box grounded?
| Display Modes | |
| trying to figure out Knob & Tube wiring on old light fixture | dalethompson | Electrical | 16 | 02-02-2012 09:42 PM |
| Ceiling fan light fixture doesn't work | c4hfam | Electrical | 9 | 03-05-2011 02:01 PM |
| Issues hooking up new light fixture | ddzc | Electrical | 6 | 11-29-2010 08:19 PM |
| Light fixture in ceiling fan won't work. | Tested DIYself | Electrical | 7 | 11-28-2010 12:52 PM |
| Help with wiring a new light fixture | tinkin3 | Electrical | 10 | 09-09-2009 10:26 PM |
