New Switch Wiring, Old Box - Electrical - DIY Chatroom Home Improvement Forum
Old 10-01-2010, 02:56 PM   #1
I replaced a light and the switch loop wiring to the switch box. The old wire was knob and tube so the switch box has two knockouts removed. The new NM cable uses only one of the holes. Is it required to plug the unused hole and if so what methods can be used? The knockout is the same size as those for NM cable on modern metal boxes so they're too small for 3/8" knockout plugs.
Ptron is offline   Reply With Quote
Old 10-01-2010, 03:51 PM   #2
joed's Avatar
Rewards Points: 11,590
It is required to plug the hole. It is also required to have a proper clamp for the cable. If the box doesn't have proper clamps then replace it. If it has regular round knockout holes then you can install a clamp and get a plug that will fit the knockout.
Old 10-01-2010, 04:16 PM   #3
It has proper NM clamps. I'd rather just plug the hole if I can. I have to cut a big hole in the plaster to replace the box it as it has a stud-face mounting bracket. I've replaced one before and it's a pita.
Old 10-01-2010, 06:43 PM   #4
Licensed electrician
Rewards Points: 1,028
The NM clamp from the box should almost seal off the unused KO.
Old 10-01-2010, 10:23 PM   #5
joed's Avatar
I think you should be fine. Most of the K&T boxes I have seen were just holes in the box with wire with loom over them coming through. NO clamps.
Old 10-02-2010, 09:57 AM   #6
Thanks folks. Sounds good.
This house was built in the late 40's so I'm guessing it was the later days of K&T. The boxes are just like the modern metal ones, with clamps. The wiring is in pretty good shape too.
Wiring an Intermatic Wall Timer in a three way switch aitutaki98 Electrical 6 07-23-2011 12:43 PM
Switch on K&T wiring - OK to pigtail? fdmillion Electrical 4 01-27-2010 10:15 AM
Wiring of a contactor LC1D091o to a daynight switch kalulu Electrical 3 05-01-2009 03:09 PM
Wiring two floodlights to a triple switch chrisjardine12 Electrical 20 01-23-2009 01:29 PM
Ceiling Fixture / Switch Wiring gregger Electrical 1 10-21-2006 08:47 PM
